why so slow
Old Feb 2, 2009 | 09:11 PM
FI'ed G's Avatar
Originally Posted by ska12
and the car only hits full boost the first time i drive it everyday or when the engine is completley cool. and its been like that for months. if i punch it in third gear the boost goes up slower than the rpms.
Here's another no no... You have to let the car to warm up before you start going WOT, the oil need to reach a certain temp before it can protect your car. Dont do this again RPM will always be faster than boost with SC like Vortech. With Centrifugal SC you dont hit full boost until Redline..
Old Feb 2, 2009 | 09:24 PM
ska12's Avatar
haha im not that clueless i know i have the vortech and the injectors are stock because i havnt upgraded the serp pulley so theres no need for new injecors yet. I admit i dont know much but i have had the car checked out already by phantasm and they did a dyno and a compression test and it was ok. I cant answer your question yet about the a/f because i need to go drive it and look but the lights on my guages recently went out so i gotta get that fixed along with an idler pulley where the bearing went bad. and also sorry for not knowing alot about mod cars im trying to learn. the car isnt heavily modified all thats in it is the vortech. And what is the difference between Engine control unit, and engine management system?
Old Feb 2, 2009 | 09:35 PM
GinFLA's Avatar
The ECU is the computer in the car that controls all the engine parameters (IE A/F, timing, etc etc)
An Engine Management System allows you to reprogram those parameters to meet your needs.
Since you have a vortech, I hope you arent running the stock programming. If you are, go out and get a stand-alone engine management system (UTEC recommended) and go to someone who is experienced in tuning these cars in your area.
Are you running a front mount intercooler as well?
Old Feb 2, 2009 | 10:12 PM
ratm68's Avatar
Maybe you're not boostin because you're not at WOT. Eventhough the vortech is a centrifigual charger that does increase boost with RPM, it only boost at WOT. Boost doesn't just come with the RPM, i think most people forget that (or don't know that) about the vortech.
Regardless, get it checked out by a G/Z specialist that have tuned or worked on a vortech before. Since you and the prior owner don't know anything about the car, it's best to get to knwo it, or better yet, just get it tuned so you atleast know where you stand with the car.
Driving it around and asking us questions..won't give you the answer, because we simply don't know what went into that car or what stage of the build it's currently at.
Goodluck...it's a tough forum, i guess we expect the members to use better judgement..i guess we're a lil snobby..haha
Old Feb 2, 2009 | 10:38 PM
by15vc's Avatar
UTEC is a piggyback not a stand-alone
OP: Where are you located? Maybe we can recommend some shops for you to bring your car to get checked out cuz it definitely needs some work done...tuning at the very least.
Old Feb 3, 2009 | 10:06 AM
ska12's Avatar
Yea i got the front mount intercooler. Im located in Wake Forest, NC. And im pretty sure the best shop is in wilmington NC called National Speed.
Old Feb 3, 2009 | 10:19 AM
str8dum1's Avatar
haha, u said phantasm. LOL. ya they work on some serious BS there.
do u have a wideband gauge? i'm in raleigh and could look it over.
if they dyno'd it, post that up, bc it should have your AF curve in it as well.
Old Feb 3, 2009 | 10:29 AM
ska12's Avatar
I have the a/f, fuel pressure, and boost guages. and if you could look it over that would be great seeing how i dont know enough and serioulsy need someone who does to look it over.
Old Feb 3, 2009 | 10:32 AM
GreenGoblin's Avatar
The goblin resurrection
I have some rc 440 injectors that you need, I hope that you ready for what you got yourself into.
Old Feb 3, 2009 | 10:35 AM
ttrank's Avatar
Grocery getter
OMG, I can't imagine driving in boost with no tune.
What's your A/F vs boost like when you are on it?
Old Feb 3, 2009 | 10:39 AM
ska12's Avatar
Im gonnna get the 550 injectors when i upgrade my serp pulley to the 2.87 but im getting either the utec or the haltech asap and i wont drive it until then.
Old Feb 3, 2009 | 11:25 AM
Jtrain's Avatar
Check piston PSI
Old Feb 3, 2009 | 12:56 PM
XKR's Avatar
XKR
haha i thought this website was to help people... Not be *********. But whatever.
And who told you this We are here to kill noobs that dont use the search button
Guy...Take your car to a shop that knows G/Z's ...You can go north to PFS or south to FP.....Any day now
Old Feb 3, 2009 | 01:25 PM
  #30
ska12's Avatar
ok im going rite now
