Battery Drain
Old Feb 10, 2009 | 06:25 PM
GeeRider's Avatar
Battery Drain
theres a slow draw on my battery because of the supercharger and other electronic stuff installed. I need to plug it in every week or so to make sr theres enough juice there when i need it. Is there a specific or special type of battery i can get that willl have enough or more power. I hate having to plug it in. Do you guys have the same problem with ure's ?
Old Feb 10, 2009 | 07:08 PM
XKR's Avatar
XKR
Are you sure its not just your battery not holding charge When your car is running...what is your voltage reading. 13? 14?
Old Feb 10, 2009 | 07:11 PM
GeeRider's Avatar
im not sure what the coltage readng is, when i bought the car the battery was already changed. Its not the stock battery. And the car only has 46,000 kms on it so im guessing my battery wouldnt go bad that quickly, or can they? If im not mistaken i think its actually a dry cell battery
Old Feb 10, 2009 | 09:05 PM
GeeRider's Avatar
did u try changing your batttery? , i dot want to buy a new one nad have to end up returning it or sumtin cause dat dun solve the problem
Old Feb 11, 2009 | 09:44 AM
FI'ed G's Avatar
Never had this problem before too but this past 3 weeks I had to jump start my car when it sits for more than 6 days. I only drive on the weekend for the most part and my car always start up fine even in the Winter or even if my car is sitting for almost 2 weeks. I guess I'll need a new battery soon.. Well we had the worst winter in 5 years here in the NE so that could be the problem too...
Old Feb 11, 2009 | 01:24 PM
ttrank's Avatar
Grocery getter
I had this problem with my last battery. I have so many aftermarket electronics on my car they will kill the battery over time. I went out of town and didn't drive my car for over a month. My optima red top was dead ~3V and my charger could not bring it back to life, nor could optima. I got a new one and make sure to pull the negative terminal if I am going away for more than a week. Things have been fine since.
Just because you don't have that many miles doesn't mean your battery isn't in need of replacement.
Old Feb 11, 2009 | 01:25 PM
duggy's Avatar
Ouch. Electrical problems suck ***!
Old Feb 11, 2009 | 03:37 PM
GeeRider's Avatar
so if i repleace my battery and basially drive my car everyday, nothing should go wrong?
Old Feb 11, 2009 | 03:47 PM
escobar929's Avatar
i had this problem too, but once i replaced the battery it went away
i also noticed one of the terminals was loose, you guys may wanna check that the terminals are nice and tight
KruZZe
Feb 27, 2023 05:04 PM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
g.spot
May 9, 2016 10:54 PM
dcsbh1
Oct 1, 2015 03:15 PM
G35CO
Sep 4, 2015 09:27 AM
