Checklist.. quick help guys!
Old Feb 13, 2009 | 11:19 AM
ezpotato's Avatar
So i got my used SC vortech kit... just wanted to see if people saw anything major missing or anything. what gaskets am i going to need? didnt get any.. thanks! oh btw, i do have a walbro sitting here, just didnt get a pic of it.
the belts i have:
blower and pulley
gauges
greddy 440cc injectors
oil pan spacer and bolts and clamps
I am assuming fuel return stuff?
I have no idea! hahah
Overall shot, ACT and Exedy stuff too. (ignore the tranny sitting in the bottom.. not mine)
piping
wiring?
Old Feb 13, 2009 | 11:58 AM
teamspink20's Avatar
that stuff where you said you have no idea is all the wiring and sensors for the defi gauges
Old Feb 13, 2009 | 12:52 PM
ezpotato's Avatar
haha that's what i thought, but i'm so bad at the electrical part of everything... i just know the rest of the hardware. thanks a lot though!
Old Feb 13, 2009 | 09:14 PM
serturbo's Avatar
what package is that? Im assuming V2? I thought about buying a used kit but convinced myself to buy a new tuner kit so that everything needed to install is ready to go..
Old Feb 13, 2009 | 10:36 PM
clifftrail's Avatar
That black box is the SS box or the fuel controller for the vortech kit and looks like you got a nice plug to go right to the ECU so you won't have to splice.
Also, the fuel lines isn't a return system but the auxiliary pump for the vortech. It splices into the existing fuel line and supplements the S/C with your SS box tells it to. Go to the vortech website and you can download an instruction manual that will help you understand your pieces and parts much better.
Old Feb 14, 2009 | 12:14 AM
Chef-j's Avatar
Looks like you got a full kit from seller.
But what about ACT/Exedy??
Old Feb 14, 2009 | 02:09 AM
ezpotato's Avatar
yeah i bought off sin3.. he pretty much gave me everything including the clutch and ****.. really good deal. cant wait till it's in.
thanks for the info guys, helped out a lot!
Old Feb 14, 2009 | 12:24 PM
Sylvan lake V35's Avatar
Its nice the SS box is wired into a patch harness makes for an easy install.
Old Feb 14, 2009 | 07:56 PM
ezpotato's Avatar
man i really wanna do the install myself, but i'm just scared. it seems easy. i'm just so confused about all the oil lines and gauge wiring...
also, this set up with the vortech stock flas that it comes with.. i should make around 340-360 right? and if i update to like utec or something, it will be better tuned?
Old Feb 15, 2009 | 01:04 AM
Chef-j's Avatar
^ you should be fine with FMU/SS.
Old Feb 15, 2009 | 09:46 AM
clifftrail's Avatar
You'll be in the same neighborhood with the vortech system software. Its all about the tuner and what he/she is good at. If they are familiar with the SS box and software you'll be in the same ball park as the other systems.
That power rating is in the right area for the stock pulley.
It easy to install the vortech, installation is not hard just time consuming and for you, tapping the oil pan will be your biggest challange since you have the wiring harness adapter.
If you decide to DIY, plan on the car being down 3 days and have a back-up plan for transportation. GL.
Old Feb 15, 2009 | 12:04 PM
ezpotato's Avatar
honestly that's the only thing that's preventing me to do it myself, the oil tapping... i have NO IDEA how to do anyhthing with anyh of that oil/wiring/fuel stuff, i'm sure i could figure it out with the help of some friends, but man, just payiong for it sounds good haha
i do have back up transport... thanks a lot clifftrail, makes me feel better about the stuff.
Old Feb 15, 2009 | 02:57 PM
clifftrail's Avatar
I never did a S/C install either but I went ahead and did the Vortech when I got it in my garage with common tools (except the oil tap). The instructions are very good from Vortech and it just took time and patience. If your an average joe around a car and you can distinguish a fuel line from a vacuum line, then installation of the vortech is simple.
And the kit you have is even easier because of the completed wiring and looks like everything is still together, that makes installation of all the fuel, oil, vacuum and wiring that much smoother.
Mry
Mar 3, 2023 01:03 AM
skippyG
Jan 25, 2016 01:18 PM
bTanz
Oct 15, 2015 02:31 PM
Soumilg
Jul 18, 2015 12:33 PM
