Auto Tranny Guys
Old Mar 21, 2009 | 02:40 AM
IrockAG35's Avatar
Ohio G Club moderator
Originally Posted by SDGeneralCounsel
how do you know? Frankly any boost on the 5AT tranny is touch and go. The only real problem under boost is that the transmission doesn't shift gears fast enough with the added power. A VB upgrade is a must at one point, and realistically a fully built tranmission is a smart idea as well.
I have yet to see a 5AT fail due to any boost, no matter the power the engine is producing.
OP a tranny cooler is a smart idea as well.
just what ive seen on the forums..dont know much about the tranny upgrades and what the stiock can handle
Old Mar 21, 2009 | 06:03 AM
Canadian's Avatar
Canada, eh?
I had mine fully built a few months ago and I love it. It feels like a different car under WOT but pretty normal under normal driving. The VB is the biggest change you can make that you will feel. If you want your tranny to last, I recommend doing a build. The VB won't make your tranny last longer, it will just help with quicker shifts. Boost + 5AT stock tranny may not last too long depending on how you drive. You also could be fine, its like boosting the stock motor. You never know what could happen.
Old Mar 21, 2009 | 01:22 PM
G37Rider92649's Avatar
400whp and you'll be fine on your stock tranny? HAHAHAHAHAHAHAHAHAHAHAH
Ok, Do it then. I'll wait for that new thread in a few-months you'll make.
Da Fvck's the point of NOT buying a VB upgrade, sheesh, can't cheap out in the end. IMO, you go over 320whp, VB upgrade is a must, well atleast for ME.
Old Mar 21, 2009 | 01:39 PM
Jtrain's Avatar
Originally Posted by booger
IMPO
with a vortech , any tranny mods really arent needed . But adding a valve bady will help with shifts . I would add a tranny cooler also .
I have the SGP valve body and it shifts hard but isnt stock felling in several respects . It down sifts to hard when creeping to a stop .
Don't listen to that. If you go F/I with a 5AT get a cooler RIGHT away. and plan on gettin a new VB very soon. If you want nice 60' and 1/4 mile times get a medium stall TQ converter.
2200-2800 stall
Cananda did it right. And when you look at the total build cost- the tranny is a big part but a ness evil.
Old Mar 21, 2009 | 09:42 PM
SDGeneralCounsel's Avatar
Originally Posted by urban
Actually mine did start to fail, the rpms would just go up and the tranny would not shift into the next gear, a good sign that the clutchpacks were on there way out. I was pushing 430 with the Vortech when this happened.
Really? Good to know.
Old Mar 21, 2009 | 09:45 PM
Yeah, you had a meaningless torque converter installed as well and whatever else not needed GTM installed for you.
For just a vortech you are good on a stock transmission. I've been boosted with a vortech for over a year now, without any transmission mods. Secondly, if you know me, then you also know how I drive. I'm always in the boost.
Old Mar 21, 2009 | 10:55 PM
Jtrain's Avatar
VB + cooler is a must with F/I
TQ converter if you want a good time slip.
Build the rest if you want it to last and want to get 400+whp
/Close thread.
Old Mar 22, 2009 | 03:53 AM
GTM's Avatar
GTM
OP: Most of the people in this thread are completely wrong, have no idea how an automatic transmission works, and are posting as experts - when in fact they are the farthest thing from it.
A valve body upgrade is probably the most effective modification you can do to your 5AT, you will yield the most 'bang for your buck' and will achieve the following:
-Increase line pressure in the transmission
-Less slip on the clutch packs due to the increased line pressure
-Less heat (lower trans temps) developed by the transmission due to lack of slipping clutch packs
-Firmer shifts when on the car hard, but OEM drive ability while driving the car properly.
Hence the comment 'it will only make your car shift faster' is not true, trying building a transmission by just replacing the clutch packs and not modifying the valve body, you will be very disappointed.
It is important to upgrade your valve body before any slipping of the clutch packs/damage occurs. I would recommend installing this modification before installing any forced induction kit in order to get the most out of your transmission.
Now, that fact that a torque converter does nothing is also completely false, why do we modify our cars? To make them faster right? An after market torque converter can do 2 things:
1) Increase your stall so that you can achieve faster 0-60 times, 1/4 mile times, drag times, etc. If you want to race from a stop then this is a good choice.
2) lower your stall speed in order to make the car feel more like a manual transmission with closer shifts, so if you plan on road racing this would be a good choice.
If you are on a budget, just opt for a valve body upgrade, the Transgo kit is the only kit worth installing, but keep in mind with an automatic transmission, the installation is far more important the just the parts.
Good luck on your future power ventures, and please let me know if you need anything, the amount of misinformation on this site regarding serious power modification is ridiculous.
-George
GT Motorsports
Old Mar 22, 2009 | 10:47 AM
rcdash's Avatar
^+1 Listen to this man. The GTM-5AT with paddle shifters is a dream come true for me. Coming up on 10k miles driving in the 450-520 whp range and still shifting firm, quick, crisp. Thanks GTM! (Sam, I had the fluid changed at 6k as you instructed!!! No worries .)
Old Mar 22, 2009 | 12:21 PM
sliderg35's Avatar
Did I mention not to get the Stillen VB upgrade? I did; it totally pooched my tranny. They did not admit any liability but they did fix the VB so it wouldn't blow the tranny every time it went into 3rd gear. Now it shifts very sloooowly into 3rd, but at least it drives ok.
Old Mar 22, 2009 | 02:00 PM
urban's Avatar
I think I am coming up to 40k on the GTM tranny with no issues. Man I drive way too much
Old Mar 22, 2009 | 09:01 PM
keff108's Avatar
Thanks George that was the exact Info I was looking for. When it comes time to upgrade my tranny before going FI I will be looking in GTM's way. Heard nothing but good things from you guys. Keep up the good work over there.
Once again thanks for all that info.
Old Mar 22, 2009 | 09:08 PM
zt967's Avatar
-George
GT Motorsports
Spoken like a true professional.
Old Mar 23, 2009 | 04:21 PM
  #30
Jtrain's Avatar
Okay then Mr. Professional =P
What is needed to stop 400rwhp+++ slippage and why?
