need help finding greddy TT kit misc parts.....
Old Mar 27, 2009 | 05:59 PM
deanfootlong's Avatar
i have a greddy tt kit, but am missing a few parts. for instance, i need the oil supply parts that tap off of the oil pressure sending unit and some other stuff.
ive talked with gtm, and intense motorsports about ordering these from greddy, no dice. can anyone help me find somewhere where i can order this stuff from?
i have a built motor that im almost done putting together and need to get these crucial parts together so i can be ready to install it. and yes, i'll make another post with pics when im doing the install.
first heres a reference for what im talking about: attached is the install parts list from greddy site from which i need to order a few parts through you from. http://greddy.com/img/PHP/products/p...INST_PART1.pdf
so what i need are parts numbers on the list:
21. Oil Pressure Union Fitting 3-Way Fitting 2 of them
22. “ 1/8PT – 1/8 PT Straight 2 of them
23. “ 1/8PT – 1/8 PF Straight 1 of them
24. “ 1/8PT – 1/8 PF Male to Male 90° 1 of them
45. Power Steering Pump Fitting 1 of them
55. Turbo Gasket TD05 In / Out 4 of them
57. Oil Return Gasket TD Small 2 of them
any helpers?
thanks a bunch
charles
Old Mar 27, 2009 | 08:31 PM
serturbo's Avatar
Hey what's up man.. I talked to you a while back about helping me with my vortech install... hopefully you find the pieces you are looking for.. I would love to take a look at your ride and see how the built motor is progressing along.. And when its all put together I call dibs for a ride in your TT G
Old Mar 27, 2009 | 08:41 PM
GreenGoblin's Avatar
The goblin resurrection
I have some of the fittings, and gaskets
Old Mar 28, 2009 | 12:05 AM
nyqueenz's Avatar
try this place or any place were you can buy turbos or have them re built they should have what you need..
http://turboaddictionparts.com/catal...ain_page=index
Old Mar 28, 2009 | 12:07 AM
nyqueenz's Avatar
http://www.aptuning.net/Turbo_Oil_Supply_s/157.htm
Old Mar 28, 2009 | 01:43 AM
baileyrx's Avatar
I ditched to greddy oil fittings and used a sandwish adapter off my oil filter. Much better than the greddy set-up. Which looks like someone put it together in there garage with spare parts! Anyway I have the p/s fitting, but it has a small crack in it which can be carefully welded. It's aluminium.
Old Mar 29, 2009 | 05:56 PM
hmm maybe i'll do a sandwich. anybody know where i can get a decent sandwich with two supply ports on it?
Old Mar 30, 2009 | 12:52 PM
specialist's Avatar
jrponline.com
Old Mar 31, 2009 | 04:00 PM
jtranstudios's Avatar
you can always just call greddy and order it from them.
Old Apr 1, 2009 | 01:29 PM
i cant find the number to call greddy directly on their site for the life of me. i have emailed them, but that was three weeks ago and no response.
thank you guys for posting places to get fittings from; unfortunately they dont sell the fitting i need. i need a 1/8PT ti 1/8PF. the key part is the PF since thats what greddys oil supply lines take. regular 1/8 inch PT work work since PT is not a parallel thread.
i need a parallel fitting that will thread all the way into the oil supply lines. pipe tap thread wont work. super hard to find these fittings for me. ive been the industrial parts stores and found nothing.
does anyone have a number where i can call greddy directly?
Old Apr 1, 2009 | 01:47 PM
GREDDY PERFORMANCE PRODUCTS
9 Vanderbilt, Irvine CA 92618
Tel: (949) 588-8300 FAX (949) 588-6318
info@greddy.com
www.greddy.com
its on there website under the GPP thing.
Old Apr 1, 2009 | 01:58 PM
Hi-TechG35's Avatar
Good luck on getting parts from Greddy as I know and have heard it is almost impossible to get parts for their kits.
Old Apr 1, 2009 | 02:17 PM
well you were right high tech G. they wont sell me parts. damnit. i have to have a dealer do it for me. and i have tried and tried and no dealers will order it for me. such a PITA.
they recomended that i print out the install sheet with the parts that i need. then circle the parts i need since they dont have parts numbers. just need to find a dealer that will do it for me..... hmmm..... anyone want my business?
Old Apr 1, 2009 | 03:04 PM
ttrank's Avatar
Grocery getter
Are you are you doing the install or is a shop?
Old Apr 1, 2009 | 05:12 PM
im doing it. eventually. still building my motor.
