GT Motorsports: GTM COMPLETE Turn Key G37 Twin Turbo kit, 455 rwhp 338 rwtq
Old Apr 3, 2009 | 09:45 AM
  #31
captj3's Avatar
George doesn't the higher compression of this motor also help with the power?
Old Apr 7, 2009 | 03:07 AM
  #32
GTM's Avatar
GTM
Yes it does, I just figured that was common knowledge but thank you for pointing that our.
Also keep in mind slightly higher compression isn't going to make THAT much of a difference, the gains are mainly attributed to the VVEL, although it was a combination of things.
-George
GT Motorsports
Old Apr 8, 2009 | 02:36 AM
  #33
murdered out's Avatar
what kind of rims are those
Old Aug 9, 2009 | 11:18 PM
  #34
Mongkey007's Avatar
sry noob question.. whats the difference b/t turn key and tuner kits?
Old Aug 17, 2009 | 10:23 AM
  #35
booger's Avatar
What did this car dyno stock ?
absolutely amazing that you were able to get 455rwhp out of 5psi ! Stock the G37 AT5 should put down around 250-260rwhp . That would mean you are getting 40rwhp out of every psi of boost . ABSOLUTELY AMAZING !
Old Nov 20, 2009 | 09:49 AM
  #36
docaam's Avatar
what other parts are needed in addition to the kit? do you know of anyone in Dubai who can install it?
Old Nov 20, 2009 | 06:35 PM
  #37
SilentAttack's Avatar
Nice!!
Old Nov 23, 2009 | 01:14 PM
  #38
mx592's Avatar
Whats the reason for the X-pipe if you don't mind? Sound? Power? Torque? Just curious. I turned my EVO2 into a true dual and it got a LOT louder! But maybe that is more becuase I pretty much doubled the flow area
Old Nov 23, 2009 | 01:30 PM
  #39
Hi-TechG35's Avatar
Clean job. Sexy car! Sexy kit
Old Nov 23, 2009 | 02:43 PM
  #40
pfarmer's Avatar
Because on a piston engine what is important is to improve scavenging. A crossover pipe can help in this regard by helping to maintain velocity throughout the exhaust system.
Some of this changes however when you add a 'turbine' or two to the system on the exhaust side of the tracks (versus intake only).
Old Nov 26, 2009 | 08:24 PM
  #41
stinkytofu89's Avatar
total sleeper. very nice
Old Nov 30, 2009 | 02:07 PM
  #42
mx592's Avatar
Everything I have read on the subject indicates that once you add a turbo to the exhaust stream, all scavenging effects go out the window. Since turbo's work on the principal of differential pressure, the best turbo exhast possible is the one with the least possible backpressure. In theory, this would be nothing more than a conical diffuser (about 7-12 degree included angle, IIRC) that is about 3x longer than the entrance diameter. Obviously this is rearely possible due to packaging, sound, and emissions reasons. That is why I asked the question about the X-pipe that GTM has designed into their system. Perhaps it is for sound reasons?
Old Dec 2, 2009 | 12:39 PM
  #43
mx592's Avatar
Wanna at least give me a hint GTM?
chinee
Jun 10, 2024 07:48 PM
JMSABO
Aug 4, 2015 11:58 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
Chattzx
Jul 17, 2015 11:23 AM
