nitrous G35?
nissan can pull 2 degrees i think, might check into that... i know the osiris guys in austin do it...
im running 100 shot, with colder plugs/no tune and Stock timing. Runs fine for me. Only downside is that my Nitrous shoots in spurts, and i believe its the trigger wire that is hooked up to the TB. I have the ZEX unit, and it uses a 5 volt signal for WOT, G35's works "backwards".... gets confusing. but yeah.
I'm running a wet 75 shot. I flash my Cobb’s stock style map and go -2degs on my Timing. Car runs fine. Never has she given me any problems. Now with that said, I’m seeing gains of 67hp of my wet 75shot, when my boy running a 350z on a dry 75 shot with a protune is seeing gains of close to 90hp. Tuning makes a big differences. I have also seen guys run 75 to 100 shot with no tune run fine all day. Then go out and get tuned, 3 days later there engine blows up. Just make shore that who tunes your motor knows what they are doing.
lol you brought up a 3 y/o thread to ask a question covered 100000000000000000x?
Did you even read this thread? I will partially spoon feed you out of pity now. Things you need to look up:
window switch
cold plugs
TPS wot switch
fuel pressure switch
ignition timing + nitrous
Half the people in this thread have no idea what they're talking about anyway.. do your own research and dont rely on idiots to hold your hand. Especially when its risking a few $K worth of engine.
window switch
cold plugs
TPS wot switch
laksjd84
07-24-2015 05:12 PM
