GT Motorsports: GTM Rear Differential Cooler Kit
Old May 19, 2009 | 09:08 PM
GTM's Avatar
GTM
Exclamation GT Motorsports: GTM Rear Differential Cooler Kit
We would like to introduce our new differential oil cooler kit for all the hardcore enthusiasts out there. Heat is the main factor contributing to oil breakdown, and can lead to premature failure of your limited slip differential under extreme conditions. Traditionally a finned differential cover would be used but they usually only provide marginal improvements in cooling.
For the serious enthusiasts we have designed and developed a heavy duty differential oil cooler kit that will meet and go beyond your expectations. We know this modification isn't for everyone, but for the people that do need (serious road racing/drag/drift) we have it for you! This will also help extend the service life of your gear oil since it won't be getting as hot under extreme conditions.
We will have the basic cooler available as a standalone, with our aluminum shroud as an option. This shroud will help force air directly at the cooler, significantly increasing its performance, it also acts as a mounting bracket.
Another option will be a programmable temperature activated control unit which will control the pump to only come on once the desired temperature as been reached. This will increase pump life and avoid having the pump on when not needed.
**Purchase/Product information click on the images below:**
GTM Differential Cooler Kit:
GTM Differential Cooler Shroud Kit:
GTM Differential Programmable Pump Controller:
Old May 19, 2009 | 09:15 PM
rimshot's Avatar
This is nice. Is it up for sale on the gtm site?
Old May 19, 2009 | 09:27 PM
XKR's Avatar
XKR
How you doing George.......Thats really an impressive setup....
Old May 19, 2009 | 09:34 PM
GTM's Avatar
GTM
I'm doing well Mike, Thanks for asking - you know we can get one off these on your car with a little custom fab
-George
GT Motorsports
Old May 19, 2009 | 09:57 PM
InfinitSkyline's Avatar
George, pm me price and install. Thanks.
Old May 20, 2009 | 05:06 AM
spddmn124's Avatar
wow that is one great looking kit!!
Old Aug 19, 2009 | 04:26 PM
ttrank's Avatar
Grocery getter
How does the kit install to the diff? Does it use the drain and fill holes or do you have to tap it?
Old Aug 20, 2009 | 01:49 AM
Nickk6's Avatar
Judging pics, I am guessing they used some -8 fittings and put them into the drain and fill and then routed it to the pump/cooler.
Old Aug 20, 2009 | 02:49 AM
ttrank's Avatar
Grocery getter
Sorry, I was at work and the pics were blocked. Never mind.
Old Aug 25, 2009 | 08:08 AM
SLEeper G's Avatar
Looking for this whole setup for an 05 G35 coupe. Will you guys be able to fab up a shroud for the G? PM me with info. Thanks
Old Aug 25, 2009 | 08:49 AM
idrive_MD's Avatar
thats a sweet setup, i guess some shield of the exhaust wouldnt hurt either
Old Sep 15, 2009 | 03:04 PM
ttrank's Avatar
Grocery getter
George / Sam, does this kit use -6 or -8 hose?
Old Aug 9, 2016 | 08:55 AM
purpleharo's Avatar
Does anyone know the fitting sizes by chance? I am thinking the diff fittings are 10mm x 1.25 to -6an then run a reducer -6 to -8 to the pre-pump filter and then to pump, then the same back to the diff. Thanks for any input.
noctilucous
2nd Gen (V36) Sedan
Aug 6, 2015 08:47 PM
newg37
Jul 26, 2015 09:32 AM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
gabe3d
Drivetrain
Jul 22, 2015 11:49 AM
nascarbuff17
Jul 16, 2015 10:23 AM
