Seeking opinions on Vortech setup...
Old Jun 5, 2009 | 09:41 PM
6MTFTW's Avatar
Ok. So I have a 2005 6MT Sedan (revup). I've already paid for and bought a Vortech V-2 kit. The kit has a 928 Motorsports V+ upgraded impeller (928 Motorsports. Apparently, it flows around 15% more than the stock impeller (puts it at about the T-trim output level). What I'm trying to figure out is if I should run this kit with the included 2.62 pulley, or get a 2.87 pulley? The kit also comes with a 928 Motorsports boost limiter (limits max boost). If I were to install the limiter, I'd hit boost sooner and it would keep boost at a safe level...
So..... run the 2.62 with the limiter, or 2.87 without the limiter?
Oh, here are my other mods/what's in the kit:
32T cog
525 cc injectors
Walbro pump
Kinetix SSV
Megan resonated test pipes
Stillen TD Gen 2 exhaust
stock block...
Any input and opinions are greatly appreciated.
-Jerome
Old Jun 5, 2009 | 09:50 PM
6MTFTW's Avatar
Oh, here's a link to the kit, in case it helps base your opinions:
Revup vortech kit!!!!!!
Old Jun 6, 2009 | 04:45 PM
str8dum1's Avatar
just read the thread that he made before he sold the kit. everyone of your questions has already been answered.
all in all run the 2.62 without the limiter. then run it on the dyno. you prolly wont make anywhere near enough torque to make you wanna take it off.
Old Jun 6, 2009 | 07:34 PM
SDGeneralCounsel's Avatar
32T cog
525 cc injectors
Walbro pump
Kinetix SSV
stock block...
-Jerome
loose the bolded items. You should probably go with a utech as well.
Old Jun 8, 2009 | 07:01 PM
6MTFTW's Avatar
Working on the Utec.
I'm keeping the SSV. Too much "he said, he said" crap about power gains/losses. It looks nice. It sounds nice. It's staying.
And, what's wrong with the Megan test pipes?
Old Jun 8, 2009 | 11:13 PM
6MTFTW's Avatar
You sure the combination of the 2.62 pulley and the upgraded impeller are going to be ok? I've been doing a lot of research and haven't found anyone running this exact setup on a rev-up...
Anyone else have any input?
Old Jun 9, 2009 | 02:09 PM
str8dum1's Avatar
just run it on the dyno, if you start seeing # over 450 hp, then back off. takes 30s to swap. i just dont think it will be that high.
Old Jun 9, 2009 | 02:16 PM
eljoker's Avatar
you have a revup sedan?
Old Jun 9, 2009 | 07:22 PM
6MTFTW's Avatar
Yes...
Old Jun 9, 2009 | 07:35 PM
eljoker's Avatar
Yes...
im sorry but i honestly didnt know they exsist, did you swap?
Old Jun 9, 2009 | 07:38 PM
6MTFTW's Avatar
You serious?
All 2005-2006 6MT Sedans have the rev-up...
Old Jun 9, 2009 | 07:42 PM
eljoker's Avatar
You serious?
i honestly didnt know that, i thought it was only the coupes
seagrasser
May 3, 2022 09:43 AM
Marlin84
Apr 1, 2020 12:52 PM
jeffbdye
Jun 1, 2018 03:51 PM
