TT ---> REV up vs. non Rev
Old Jun 22, 2009 | 03:58 PM
acsracing's Avatar
So I'm thinking of building a turbo motor and I have a clean canvass, as I don't have a motor yet. Should I build a rev up motor or a non rev? I'm planning on going TT with the motor or at least a single turbo, but it will be built for boost. Any help would be great...also please give me the reasons why one is better over the other.
Thanks!!
Old Jun 22, 2009 | 05:56 PM
Bestswat's Avatar
Im not sure what the difference is but i know rev-up is better and people who would buy a rev-up engine as a spare engine to build it for boost.
Old Jun 22, 2009 | 09:38 PM
str8dum1's Avatar
well they dont use the same ECU either, so you'll have to source a new stock ECU (get that programmed by the dealer $$$) and get a full wiring harness ($$$$$).
If you get a nice EMS you can control intake and exhaust cams on the rev-up . In reality it doesnt matter much as either motor has made big numbers.
Old Jun 22, 2009 | 09:58 PM
leojang's Avatar
What kind of power are you trying to get?
Old Jun 23, 2009 | 12:11 AM
acsracing's Avatar
Thanks for all the info guys, is there a stand alone computer I can run, not to run ECU at all and bypass the security and all that stuff? or will I always have to run a stock ECU and do all the add ons?
I guess I'm thinking I will be going with a non-rev up
Old Jun 23, 2009 | 11:56 AM
silver g's Avatar
^ I beleive you usually still have to run the ECU as there are things that require the stock ECU independent from tuning.
BTW I have a VQ35DE shortblock for sale if you want it. Perfect candidate for a rebuild.
Old Jun 23, 2009 | 11:57 AM
str8dum1's Avatar
if you want a race car, then you can use a MOTEC and skip everything thats on the CAN bus system. That would easily run ya 15,000$ just for that though.
but otherwise, you have to use a stock ECU and wiring harness.
sound like you have lot more planning.
Old Jun 23, 2009 | 10:02 PM
rcdash's Avatar
You potentially might be able to use a Haltech for what you intend to do - contact Hal at Injected Performance for details if you're serious about it. Good luck.
Old Jun 23, 2009 | 11:34 PM
sharif@forged's Avatar
What G35 do you currently have? Is it rev-up or non? This will determine what to use. I see no compelling reason to run a rev-up, if you have a non-rev-up, or vise versa.
Give us some more background, so we can help you.
Old Jun 24, 2009 | 04:45 PM
acsracing's Avatar
I have a non-rev, which leads me to believe to run a non-rev.
Silver G...what do you have and how much?? I found one locally, but it's a little expensive for what I'm looking for.
I don't think I want to spend 15k just on the management. I'm hoping to do everything under 12K and make it a streetable and reliable car, which I think should be do-able.
Anything else you can think of that I should consider before starting this build? I'm hoping to have it all done and complete by December, so I still have some time to get it done.
Old Jun 26, 2009 | 10:40 AM
silver g's Avatar
Its a VQ35DE (Non revup) shortblock. It def needs to be rebuilt as there are quite a few miles on the engine. But it has always ran strong with no major issues. I am asking $500+shipping for it. Let me know what you think, and I am def willing to work something out with you.
Old Jun 26, 2009 | 11:11 AM
acsracing's Avatar
How many is quite a few? What comes with the motor?
Send me your zip code as well just so I can get a shipping quote. Also, are you willing to take it to a freight depot and put it on a pallet?
Thanks, Adam
Old Jul 1, 2009 | 12:31 AM
silver g's Avatar
Thanks, Adam
Sorry just checked back on this thread. As for the miles it has 104K on it...like I said def needs to be rebuilt (perfect for a rebuild). You get simply the shortblock with nothing else.
This would give you time to build it up, keep your car running in the meantime, and when it is time to install just transfer over anything and everything you can from your current motor (i.e. heads, covers, plenum, wiring, etc.) Yes i can take it to a freight depot. My zip code is 92673.
06g35
Feb 14, 2022 05:59 AM
Thebaws11
Nov 30, 2016 12:54 PM
mbe32
Nov 13, 2015 11:09 PM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
vamarris
Sep 26, 2015 12:56 PM
