Vortech Help
Re: Vortech Help
i dont see why it wouldnt fit. i am willin to bet that some of the pipin for the intercooler would be off. like you said the splitsecond box would be setup different. how different i have no idea.
i dont own a vortech and havent done much research on them cause i will be goin the turbo route, so i could be totally wrong. those are just my thoughts on the subject.
Daniel
03.5 5AT DP Coupe
Ground Kit / Z – Tube / Shock Sensor / 5% Tint - 30% Windshield
Clear Corners / L.E.D. Hood Lights / KPTech VDC Memory
KPTech OEM Remote Window Up / Invidia Exhaust
Daniel
03.5 5AT DP Coupe
Re: Vortech Help
i am fairly sure the inlet and outlet of the compressor are slightly differently canted, and the mounting is a bit different too....
DEF. call vortech to get the specs..... this prolyy will be an issue!!
seagrasser
May 3, 2022 09:43 AM
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
n2fooz
Sep 4, 2015 07:46 PM
