Boosting a 5AT?
Old Aug 22, 2009 | 08:27 AM
brotus's Avatar
I've recently installed a procharger on my 5AT. I only have about 3K miles on it so for and am currently looking into a valve body upgrade. As, far as the trans cooler is concerned where have you mounted it? The intercooler and piping make it a very tight space up front. I also came across the Derale trans cooler which looked like it would be great for mounting. Any thoughts on this?
http://www.summitracing.com/parts/DER-13250/
Old Aug 22, 2009 | 11:08 AM
sliderg35's Avatar
Mine is passenger side beside the intercooler where the fluid reservoir was.
That heat sink trans cooler doesn't look like is has very much surface area - it doesn't look like it was intended for high-performance applications.
Old Aug 22, 2009 | 11:43 AM
pabg35's Avatar
Simple Ax6 G
hope this help with locating were to put your cooler, but also depends what bumper you have also.
I have a setup like this, oil cooler on one side and tranny cooler on the other. My plumbing and lines are facing down and I also have a karuma z bumper.
http://my350z.com/forum/shop-builds/...c-376rwhp.html
here are some coolers to choose from. Different sizes
http://www.summitracing.com/parts/BMM-70264/
http://www.summitracing.com/parts/BMM-70266/
http://www.summitracing.com/parts/BMM-70273/
Old Aug 23, 2009 | 12:12 AM
urban's Avatar
Here is a close up of one of my coolers in the front grill, this was with the stock bumper. This the B&M oil cooler.
Old Aug 24, 2009 | 12:48 AM
Canadian's Avatar
Canada, eh?
I just took some pics yesterday of my cooler we recently installed..
B&M cooler, 29,000 BTU 11 x 11 x 1.5 I believe.
Old Aug 24, 2009 | 10:31 AM
rcdash's Avatar
Valve body and large cooler (11 x 11 x 1.5 recommended, like Canadian's) and you'll be set for FI. I use the Tru Cool model 4590 (low pressure drop, designed to bypass cold trans fluid).
A boosted 5AT will outrun most 6MTs with significantly more power. You will enjoy it!
Old Aug 24, 2009 | 10:48 AM
NaiveRapture's Avatar
Why is this?
Old Aug 24, 2009 | 01:41 PM
rcdash's Avatar
Originally Posted by NaiveRapture
Why is this?
Because you maintain boost during shifts and the shifts are quick! A 6MT driver will have to flog the transmission in an attempt to keep up. On the dyno, you will take a 5% additional drivetrain loss - there's no getting around that.
Old Aug 24, 2009 | 02:07 PM
Canadian's Avatar
Canada, eh?
No boost loss FTW
Old Aug 24, 2009 | 03:16 PM
When shifting do you still get some blow off noise or is that completely eliminated since you maintain boost through the shift? Sheeeeeit, I'd almost go turbo for the noise alone! hahah
Old Aug 24, 2009 | 03:51 PM
rcdash's Avatar
I don't hear my recirc BOV unless I let up on the throttle. I'm not one for the noise though (hence no BOV). I would have my car running silent if anyone made a quiet performance muffler system for FI (Motordyne will soon!).
Old Aug 24, 2009 | 04:24 PM
urban's Avatar
Same here no BOV sound when changing through the AT gears unless I intentionally let off just to hear the sound
Old Aug 24, 2009 | 04:25 PM
Damn, I'd be doing that crap all the time haha.
Old Aug 24, 2009 | 04:50 PM
Canadian's Avatar
Canada, eh?
I do that allll the time lol
Old Aug 25, 2009 | 10:24 AM
  #30
CDN_G35's Avatar
Any videos Canadian?
