Vortech Install Questions
Old Sep 21, 2009 | 12:28 PM
shmezelk8's Avatar
My question is if you're getting a Vortech tuner kit installed, are these supplemental parts all you need or is there anything else? I will be bringing the kit and parts to a shop to have everything installed and tuned there. I have been reading up and this is what I think will be necessary.
-Vortech V3 tuner kit
-Utec unit
-DW 660 injectors
-Walbro Fuel Pump
-Stage 4 Clutch/Flywheel combo
Also considering a 5/16 plenum spacer, and 3.9 final drive. As far as exhaust, I don't want anything too loud so maybe the HR Y pipe and coupe middy. Is there anything else to look into? Gauges, intake....
Thanks in advance!
Old Sep 21, 2009 | 01:01 PM
Brwn5454's Avatar
List looks good.
Exhaust will allow you to run lower boost without lowering hp. For example I am only running 6.5lbs but getting 375 b/c of headers, test pipes, and exhaust...and other stuff.
No no to intake...it is on your blower.
I would get an oil pan spacer just to have some more oil in there...just a safety thing. And if you want to be real safe, an oil cooler. (GTM's is good and complete)
Gauges...A/F for sure. If you want more...Boost, Oil Pressure/Temp.
Old Sep 21, 2009 | 11:01 PM
shmezelk8's Avatar
Thanks. I'll keep that in mind.
PM sent.
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
RA102223
Aug 15, 2015 09:24 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
