Vortech Installed - How to get safely to tuner . . .
I had to do a sililar drive with larger injectors and stock belt and ended up geting lucky by pulling a vacuum port. It raised the A/F enough to not fowl plugs on an hour drive.
By no means the recommended way, but it worked for me.
You guys are crazy. You spend thousands on all this and risk washing your cylinder walls (and permanently losing compression) rather than paying a little extra (or nothing with AAA) for a tow?
QUICK QUESTION,,,,,,Are you using the UNICHIP that comes with the Vortech kit to tune? Or did you get the tuner kit? Just wondering. I want to go FI but need to figure out what to use to tune, and who can tune it for me locally.
Thanks..
Thanks..
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
