My Little Sedan Build
Old Dec 10, 2009 | 04:42 PM
SouthernG35's Avatar
Some of you may know of my sedan from ZDAYZ and from being around here on the forum.
Anyway a little back ground on my car. It’s a 04 6MT sedan that had been running a stock block TN setup for a little over a year. Here are a few pic of the car with the old wheel/tire combo and TN setup.
Back in February of this year while playing around with a head, cams and spray Z06 my car decided to blow the head gasket and lay down on me. Well after several months of debating on replacing the head gasket, building the VQ and keeping the TN or building and going twins, decided to ………. do a 2JZ Swap! I knew that Tech2 motorsports had put together a kit and had their car at SEMA and thought that would be cool in my Sedan. I know that a lot of guys on here are going to think what the f*ck!! First let me say that I love the VQ and think it’s a great engine. I must also say that I have always loved the 2J and a great opportunity arose for this swap to take place. After selling off 100% of the drive train, engine, ecu, wiring harness, and turbo set up I will be out less money than I would have been doing a built block TT setup (all labor is being performed at no cost to me on this setup).
Ok on to the build:
2JZ-GTE with ECU
Tech2 350Z Swap Kit
PTE67 Turbo (.71 cold side/.89 hot side)
3 Row Greedy Intercooler
100% Custom Fabricated Turbo Piping (Hot and Cold Side)
R154 Tranny
Competition Clutch Custom Twin Disk setup
Ebay Manifold (just for now to get it up and running will be upgraded to HKS later)
Turbosmart 48mm Wastegate
850cc Denso Injectors
Map ECU (AEM Coming Later)
Custom driveshaft
Tech2 Wiring Harness
BOV (undecided what kind)
Here are some parts and progress pics:
48mm wastegate
Fuel System:
HKS fuel rail
Regulator and filter
MAP ECU
Here are a few pics of the first mock up.
Here is the motor in the car for the first test fit...
Other side. The intake manifold is out for polishing.
And one with the Turbo half installed
Huge thanks to TDC for taking this on and making it happen!!!!
More updates coming soon!!!
Old Dec 10, 2009 | 04:48 PM
Jeff92se's Avatar
Red Card Crew
Interesting. You have the weight on that 2JZ? Are there going to be any emission concerns? What guages are you going to use?
Old Dec 10, 2009 | 05:15 PM
almost3flips's Avatar
I want to see this when its done!
Old Dec 10, 2009 | 05:36 PM
04G35NYC's Avatar
Sick build, subscribed.
Old Dec 10, 2009 | 06:47 PM
I live in he great state of of South Carolina where emissions are a non issue. I have Autometer gauges from the previous seup. I will be adding a EGT and water temp gauge.
Old Dec 10, 2009 | 06:54 PM
Jeff92se's Avatar
Red Card Crew
I was referring to the speedo, tack, fuel level, odo etc....
Old Dec 10, 2009 | 07:12 PM
All gauges other than the tach will work with the custom wiring harness that tesh2 made.
Old Dec 10, 2009 | 07:50 PM
GreenGoblin's Avatar
The goblin resurrection
Very cool, I cant wait to see more.
Old Dec 10, 2009 | 08:02 PM
gizmo134's Avatar
this is gonna be sweettt when done... cant wait to see it
Old Dec 10, 2009 | 08:09 PM
Beebo's Avatar
sick cant wait till its done
Old Dec 10, 2009 | 08:17 PM
thescreensavers's Avatar
Mr.202?
x2!
Old Dec 10, 2009 | 08:23 PM
Blue Dream's Avatar
I drove ttrank's car solo
Hell yeah, subscribed!
Old Dec 11, 2009 | 06:58 PM
superchargedg's Avatar
Waiting on updates.
Old Dec 11, 2009 | 10:58 PM
DougJones's Avatar
Dude, it's the guy that you see on 418 between Woodruff and Ft. Inn. This is going to be SICK! Good luck with this.
Old Dec 12, 2009 | 07:53 AM
bluemax189's Avatar
Cool!!! I'm glad it's on the sedan too. We can't ever get enough love for sedans
