Custom HKS Twin Turbo G35 Project
Old Dec 26, 2009 | 12:20 PM
mx592's Avatar
Originally Posted by IrockAG35
nice job..anyway of putting the bov somewhere else?..id say u have a small loss of power being right on the intakes.
Could you elaborate? I have never heard of losing power as a result of BOV location. It's only open under vacuum, so I don't see how it would have any effect on power?
Old Dec 27, 2009 | 02:46 PM
superchargedg's Avatar
I also installed my TT kit with the engine in the car and what a pita.Those pic's of the wrenches made me remember some of the ones i had to make.Great job on the fab work as i know i couldnt have done that myself since i cant weld worth a crap.
Old Dec 29, 2009 | 12:06 AM
InShAllAh's Avatar
OMFG, such a sexy install! I'm right behind you brother!
Old Dec 29, 2009 | 01:26 AM
Mr_pharmD's Avatar
how much whp is this putting out>
Old Dec 29, 2009 | 01:33 AM
IrockAG35's Avatar
Ohio G Club moderator
well, i think im right,im procharged and have a pressure release valve..could be a bit dif with a bov..but a friend of mine has a tt g with his bov's where urs are,a local shop recommended he move hem since they are releasing alot of hot air into his intake and engine bay..they told him hes losing a bit of powe(as im sure u know colder air=more power)..i could b wrong but im just going by word of mouth
Old Dec 29, 2009 | 01:36 AM
thescreensavers's Avatar
Mr.202?
OEM Nissan Oil Filter oh no!
change that shiz!
Nice build
Old Dec 29, 2009 | 08:15 AM
mx592's Avatar
change that shiz!
Nice build
This is the first I have heard of this...whats wrong with OEM? I always try to use OEM parts whenever possible.
I have no idea what whp it is putting out. I am on a stock block so its only running about 6.5 psi. The stock 245 rubber will spin every time when the boost hits in 2nd on a dry road in a straight line. I wouldn't be surprised if it went high 12s at the strip.
Old Dec 29, 2009 | 01:15 PM
escobar929's Avatar
sick project!
how hard is it to remove the oil filter, from the pics looks like that pipe is in the way
Old Dec 29, 2009 | 03:19 PM
mx592's Avatar
Originally Posted by escobar929
sick project!
Actually the pipe just clears it. I can still get a filter wrench on the end of the filter. Once it is unscrewed it comes directly off. The hard part is that I now have to remove the undertray every time I want to change the oil, since that pipe is in the way. That involves about 20 or so fasteners
Old Dec 29, 2009 | 03:32 PM
Sylvan lake V35's Avatar
+1 on OEM filters thats what I use, or amsoil.
Nice work on the wrenches I might have to copy you, My engine is out of the car for my rebuild but its nice to tighten things after a few heat cycles.
Old Dec 29, 2009 | 05:04 PM
surma884's Avatar
Please do let us know what you get on the dyno. I will sub this thread.
Thanks
Old Dec 29, 2009 | 05:11 PM
ttrank's Avatar
Grocery getter
Great fab work! Can't wait to see the final results.
Old Dec 30, 2009 | 09:05 AM
escobar929's Avatar
yea, i see
the undertray is not that bad, lol 20? i lost a bunch thru out the years. more like 12-15 max
Old Dec 30, 2009 | 11:44 AM
SilentAttack's Avatar
Looks awesome!!!
Old Jan 1, 2010 | 01:06 AM
  #30
If your blow off valve is heating the air in your engine bay you have bigger problems than BOV placement. Moving a BOV will not give you colder air your BOVs release the air going to your throttle body after it went through the intercoolers and I doubt it is hotter than the air coming through the radiator that it sits beside. If you are unsure of this go drive your car for 30min then go touch your intake pipe then touch your radiator, report back which is hotter.
What does a BOV do? When your throttle closes it causes pressure to build in your intake trac because the turbos/SC have pushed the compressed air into the intake track when the throttle closes it no longer has anywhere to go. The BOV releases the excess pressure so you don't get compressor surge in your turbos/supercharger.
PS don't allow that shop to even change the oil in your car if they don't know what a BOV does they shouldn't be working on FI cars.
