Talk to me about FI Cams
Old Feb 25, 2010 | 02:57 PM
TheDude's Avatar
The kit puts out plenty of power. Therefore I would say, yeah im worried about the sound as well.
Old Feb 25, 2010 | 10:24 PM
Sylvan lake V35's Avatar
I don't really think I notice the lope like a push rod motor
Here is a vid with the S1 cams and open dumps i ran it like that for a few days until I had time to get the exhaust mated with the custom down pipes. I don't have any vids with the C2s yet ...I lied I have a dyno vid i will see if I can find it.
Here it is on the dyno with the C2s and a full exhaust you can hear the idle after the run its the best I can do for you right now!
Old Feb 26, 2010 | 08:33 AM
TheDude's Avatar
Thanks, I really don't mind either of those. Hmm decisions to be made now. But... Fvck those open dumps are loud!
Old Feb 26, 2010 | 08:43 AM
rcdash's Avatar
The S2 have slightly higher lift, slightly less duration. Idle is like stock; in fact these were designed to fix idle issues with the S1 on cars with no aftermarket EMS or ability to change idle rpms.
They give their last hoorah around 6500 rpms and then fall flat. It's great for a street cam though with very nice midrange.
Old Mar 1, 2010 | 04:20 PM
They were cool for about the first 1/2hr then they became obnoxious and my ears would ring after I was done driving on the hiway
Old Mar 1, 2010 | 04:34 PM
OCG35's Avatar
they do fall at 6500 - however, they still end with higher hp than OEM... (at lest on my car they do)...
Old Mar 1, 2010 | 06:19 PM
TTG35forT's Avatar
The JWT "C" series cams perform pretty well up to 7500 rpm. I had the C2s and they worked great. I'm going with the C8's on rev. 2 of my build. As noted, you should use the JWT springs for the "C" series cams, but they are fairly inexpensive.
Old Mar 4, 2010 | 04:44 PM
djamps's Avatar
Originally Posted by Brwn5454
Your sig implies that you've got a Vortech.
If you look around, it is NOT recommended (or worth while) to do cams unless you are building the motor.
Search for a while, here or my350z.com for a response.
I've been considering cams to try to flatten out power above 6500 on my stock block build. I'm not looking to make MORE power, just trying to continue to make the SAME power above 6500 to help with the 1/4 times, ect.
Would you guys still recommend against this?
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
andrewvk
Engine - Complete Motors
32
Apr 7, 2016 01:39 PM
AJC128
Nov 1, 2015 11:55 AM
corynooooo
Sep 26, 2015 10:54 AM
UT G35
Sep 3, 2015 03:58 PM
