Reload this Page GTM Performance Engineering G37 SUPERCHARGER KIT PRESS RELEASE
Old Mar 3, 2010 | 01:11 AM
SAM@GTM's Avatar
We are please to announce the GTM supercharger system for the G37. Our GTM supercharger system will be utilizing the Rotrex C38 supercharger, The Key to the Rotrex supercharger is unique compactness, efficiency, low noise and reliability and its state of the art traction drive technology.
Great speeds and low noise are just some of the advantages of traction drives over traditional gear transmissions. Traction drives transmit power through friction forces between its rolling elements.
The Rotrex traction drive uses an elastic annulus with a small pre-span to secure contact between the roller planets and the sun shaft with a reasonable force. The patented "ramp effect" increases efficiency and reliability in the transmission by regulating the torque transfer capability on demand through self-adjusting planet geometry.
To enhance performance, the Rotrex traction drive uses a special traction fluid. These fluids are a new family of synthetic hydrocarbon oils and greases offering a series of unique performance advantages. Developed specially for its use in Rotrex superchargers, the SX100 momentarily increases viscosity under high surface pressure, enhancing the traction drive performance by securing the optimum friction between rolling elements while cooling and protecting the system.
This traction drive combined with the latest technology in centrifugal compression, characterized by high adiabatic efficiency and low noise, gives Rotrex superchargers an exceptional competitive edge over any other forced induction solution.
The GTM Supercharger kit will Have four different Rotrex compressors to chose from: C38-61 Trim,C38-71 trim, C38-81 trim,C38-91. Combined with our custom compressor housing we will offer three different stages .
Stage zero up to 450 HP (carb approval pending)
Stage one up to 500 HP
Stage two up to 525 HP
Stage three up to 550 HP
All of our Supercharger kits are available in two forms. The tuner kit form, so the professional and the end user have the flexibility of choosing what ever fuel and engine management they may desire and feel comfortable using. The second option being a complete kit including fuel and engine management solutions. With that being said, GTM will also offer an extensive range of fuel system and engine management modules to go with our Supercharger kits.
Below is a description of all the components of the kit :
-Rotrex C38 supercharger GTM compressor housing
-GTM compressor housing
-GTM Supercharger Billet aluminum brackets
-GTM billet aluminum Sc pulley
-GTM supercharger cooler kit
-Rotrex Supercharger Traction fluid
-4-Ply High Resistance Nomex Silicon couplers
-Stainless Steel T-Bolt clamps
-2.5 x 10 x 24 Bar and Plate Core Intercooler Rated @ 700hp
-Polished aluminum IC Piping
-GTM oil Filter Relocation Kit
-Cold Air Intake System (using k&n filters)
-Bosch Bypass valve
-Pre-made steel braided oil and P.S Supply & Return lines
-All Necessary Hardware and Installation Instructions
-GTM Custom mapped plug-in And play engine management for optimum engine tune and power .
-GTM Basic fuel system with Denso 600cc Injectors and - Walbro 255 Fuel Pump .
-GTM Custom Drive belt By Bando
-GTM Heavy duty Belt idlers
Some Key points about the GTM supercharger kit
After literally installing and tuning every supercharger kit available for the VQ platform and seeing their short comings, we got the inspiration to develop a kit superior to all others. Problems with the other kits that we wanted to address with our own include: not supplying a descent amount of power, belt breakage and slippage, obnoxious gear lash noises, limited power expansion and lack of the OEM look. Some of the key things we did to achieve our goal are:
SUPERCHARGER NOISE : We chose the Rotrex unit, a very QUIET supercharger compared to anything else on the market .
SUPERCHARGER BRACKETS : Our supercharger bracket is 3 dimensional made out of of thick billet aluminum to prevent any flexing, we also mounted the supercharger unit as close as possible to the engine to limit the amount of flex possible, as well as keep the belt length down between pulleys.
BELT AND TENSIONER DESIGN : We have over 80% belt wrap on our supercharger's pulley and with utilizing the factory automatic belt tensioner over or under tightening is simply not possible.
POWER EXPANTION : Changing the pulley on the super charger is less than a 20 minute job
AESTHETICS : The GTM Supercharger kit maintains the clean oem look
ENGINE MANAGEMENT: With using the GTM flash we are to able to maintain the OEM drive ability so the car will run like stock, only with a lot more power .
POWER DELIVERY : The GTM supercharger is best bang for the Buck out of the box
Here is the pics of the GTM SUPERCHARGER KIT and some of its major components
Here is the pics of the GTM SUPERCHARGER KIT install process
Old Mar 3, 2010 | 01:12 AM
SAM@GTM's Avatar
here is the power output of stage 1 supercharger kit
VIDEO'S OF THE KIT IN
ACTION
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/ueIeB1YEjgc&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/ueIeB1YEjgc&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/jpDwuKeZYdc&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/jpDwuKeZYdc&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
<object width="560" height="340"><param name="movie" value="http://www.youtube.com/v/Zc9N9xF2h_s&hl=en_US&fs=1&"></param><param name="allowFullScreen" value="true"></param><param name="allowscriptaccess" value="always"></param><embed src="http://www.youtube.com/v/Zc9N9xF2h_s&hl=en_US&fs=1&" type="application/x-shockwave-flash" allowscriptaccess="always" allowfullscreen="true" width="560" height="340"></embed></object>
PRICING
We are currently expecting pre-orders for a introductory Price of 4995.00 and for a limited time only .
Sam
Old Mar 3, 2010 | 01:15 AM
Boosted D.D.'s Avatar
Awesome kits. Sam.
Only thing I'd like to know is... Should I sell my GTM installed APS TT 2006 G35 and get this thing going on a new G37?! LOL
Seriously, Nice job.
-Leonard
Old Mar 3, 2010 | 01:29 AM
06PlatinumG's Avatar
Any plans for a G35 kit?
Old Mar 3, 2010 | 01:40 AM
stinkytofu89's Avatar
i agree
Old Mar 3, 2010 | 01:54 AM
SAM@GTM's Avatar
For the G35 HR.. yes, Press release in a couple weeks
Sam
Old Mar 3, 2010 | 09:31 AM
superchargedg's Avatar
Kit looks real nice and a damn good price!
Old Mar 4, 2010 | 02:23 PM
Kazaam's Avatar
nice
Old Mar 25, 2010 | 09:33 AM
Cabad85's Avatar
awesome! rotrex superchargers are a great design imo.
Sam, any update for the VQ35HR motor? especially fitment for the 07-08 sedans?
Old Mar 25, 2010 | 09:47 AM
beezy619's Avatar
With this kit, would you need to run test pipes or a bigger exhaust?
Old Mar 28, 2010 | 03:40 PM
booger's Avatar
ANy plans on fitting it to older models ? With the SC down low like that ?
Old Mar 28, 2010 | 03:50 PM
LordFappington's Avatar
one for the vq35 pleasssse
When Bruce Willis was dead at the end of Sixth Sense
I jizzed in my pants
Old Apr 1, 2010 | 03:40 PM
The-Dream's Avatar
Jesus that is sexy. How does the automatic transmission (5 speed and 7 speed) handle the supercharger?
Old Apr 1, 2010 | 03:43 PM
Hexxum001's Avatar
Wow, GTM still kicking some serious booty. Nice job guys.
Old Apr 2, 2010 | 09:19 AM
FlyingLumpia's Avatar
I dont know about you guys, but it makes me want a g37. BTW did you notice that 37 rocking Volk GTM and look who posted.
