G35 Turbocharged
Old Mar 15, 2010 | 07:52 PM
bludiamond's Avatar
G35 Turbocharged
Hey guys, I'm thinking of buying an 04 G35 turbocharged. Here are the specs from the seller.....
Turbonetics Turbo kit, purchased from Turbokits.com, a kintex ssv racing manifold, and a borla exhaust, also had a UTEC put in when the car was tuned, also has a 3 gauge pod with Oil Pressure, Boost, and Water Temp. This car is the most loaded you can buy from the factory has everything including Nav.
The Check Engine Light is on, talked to my tuner told him the codes and he said its probably just a vacuum leak minor fix car still runs fine.
So I was wondering is their any danger in buying this car? Its an automatic, but was wondering if the turbocharger can effect the engine or put any stress on the car? I don't wanna buy this thing and then have to dump a bunch of cash into it all the time. Also any1 know what UTEC is?
P.s. I posted this in the G35 discussion section but realised there was an FI section ;-)
Old Mar 15, 2010 | 08:49 PM
g-adabout's Avatar
UTEC is the stand alone engine management system. It takes control of the cars computer and makes adjustments so the motor can handle the new airflow from the turbo.
There could be a danger. If you know nothing about turbo setups, it would be hard to know what to look for. Like any purchase of a car, you could take it to a tuner shop that is familiar with Turbos, turbonectics, UTEC and G35s. They would be able to tell you if its worth it.
Base on your description, it would be hard to diagnos the issue of the light. I had a light but it was a o2 sensor tripped by my electronic Cut out. Yours could be anything.
Old Mar 15, 2010 | 08:56 PM
QUiKSR20's Avatar
Personally I would never buy another persons project unless it was a personal friend. Your just asking for unknowns. Buy a stock car that way you know 100% what your getting yourself into. To me that's like an un-written rule. Always buy stock or next to stock.
Old Mar 16, 2010 | 04:03 PM
jomamahama's Avatar
you want a 2nd hand turbo car which did not come with turbos from the factory and you don't want to have to dump a bunch of cash into it all the time?
That's like a paradox.
Anyway, pay however much to get the car fully inspected and set aside $5000 for repairs. If you are really set on buying an FI car, buy one that came turbo from the factory and have the same PPI done. If I were set on FI I'd just get a 300ZX TT and mod it. Do the same PPI and look for one with good paint. I like side airbags and the interior of my g35 though even though it's slower.
Old Mar 16, 2010 | 04:52 PM
abcdo4dkIdjkm's Avatar
UTEC controls the valve timing in the engine. Its kind of like VTEC but its for turboed VQ35 motors.
I couldnt see any reason as to why a turbocharger would add stress or reduce the life of the motor. Extra heat and pressure are actually very good for the internals.
I say go for it.
Old Mar 16, 2010 | 04:54 PM
FI'ed G's Avatar
Get it to a shop and do a compression/leak down test on the motor. That is the only way to find out if the motor is still good. Find a shop that know our car and had done mulitple turbo/SC install and tune and have them inspect and make sure the tune is also good.
Old Mar 16, 2010 | 05:00 PM
FI'ed G's Avatar
I say go for it.
Utec dont control valve timing.. it control the ignition..
Originally Posted by HomieG35
The UTEC is a fine system. It's not the best, but certainly not the worst. I have run it on my car for 3+ years with no issues. It is NOT a stand alone system like mentioned above. It's a piggyback so it works WITH your stock ECU and modifies signals when in boost. Speaking of boost, how many pounds is this car running?
Almost but not quite.. Piggyback? Yes... there is no full standalone for our car.. HKS,Haltech, Pro-efi are still consider a piggyback because it is not a full replacement for our ECU. They all piggyback to our ECU but they are a standalone because they have full control on anything that relates to your engine running. Utec dont modify the ECU values but instead it actually take full control of the ignition and injector just like a standalone when on boost.
Old Mar 16, 2010 | 05:01 PM
Old Mar 16, 2010 | 05:08 PM
I was clearly joking about the valve timing thing .
But you forget to mention that it also has controls for fuel (the speed density fueling is a nice feature), detects knock, and has the ability to scale injectors. All very important when going FI
Old Mar 16, 2010 | 05:10 PM
FI'ed G's Avatar
I was clearly joking.
I just realized after re-reading your post that you were being sarcastic.... I did mentoned the fuel on my next post... one thing you forgot is that Utec Temp Compensation Suck a&&
Old Mar 16, 2010 | 05:14 PM
No problem You are definetelly right about the temp compensation. Gotta watch the tune, especially in those hot summer months. Allot of people are starting to run there FI cars with uprev. Im very curious about that setup.
Old Mar 16, 2010 | 05:24 PM
FI'ed G's Avatar
No problem You are definetelly right about the temp compensation. Gotta make sure the car is tuned a bit rich for the summer months just in case. Allot of people are starting to run there FI cars with uprev. Im very curious about that setup.
I do my own tuning and I was offered to try the Osiris. After looking at the manual then it really doesnt make sense for me to switch because I'm going to loose a lot of functionality and protection. Osiris dont offer 3rd party wideband support so street tuning is a pain unless you trust the OEM 02 sensor for tuning or rent a dyno all the time. You also loose the knock control on the higher rpm and the overboost fuel cutoff with Osiris. There are more but both are good system and both have its pros/cons...
Old Mar 16, 2010 | 05:38 PM
^^^^ Good points FI'ed. I just heard that the uprev engaged smoother, and had a bit better driveability. But as you said each has its pro's/cons.
