AEM Water/Alcohol Injection Kit
Old Jun 28, 2010 | 12:00 PM
nyqueenz's Avatar
Anyone have this current setup?? If so
How much boost are you runnin with this?
Can this be intergraded into CAMP2 to run a sep display as a warning indicator?
I believe this sys uses your PSI from your boost presser to activate spray is this correct?
Hearing people say you can run window washer fluid or rubbing alcohol with water is this true?
- Universal kit includes everything you need for installation.
- Boost safe lets you retard the timing or reduce boost if the system runs out of fluid or detects an error.
- Progressive, controller-driven 150 PSI pump provides boost-dependent variable flow.
- One-gallon tank with integral fluid level sensor.
- Dash light for system status and low fluid warning.
- Alcohol Compatible (up to 50% in solution with water)
- Includes three jets to match your power requirement
NOTE: Can not exceed 50/50 mix of methanol to water
Old Jun 30, 2010 | 11:39 AM
deanfootlong's Avatar
head over to my350z.com. theres plenty of threads on water/meth injection. should find all your answers and more over that way.
Old Jul 1, 2010 | 06:18 AM
nyqueenz's Avatar
^ thanks
Kelvin Style006
May 23, 2016 03:47 AM
Mad A
DFW Classifieds
Mar 28, 2016 11:25 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Rhinos7777
Sep 6, 2015 05:36 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
