Greddy TT kit info
Old Oct 11, 2004 | 06:11 PM
GMADD's Avatar
Greddy TT kit info
Does anyone have the Greddy kit on a auto coupe ?
I will be going TT soon (spring) and need some info ?
Thanks !
Old Oct 11, 2004 | 07:05 PM
SFLG35's Avatar
FGC President
Re: Greddy TT kit info
yes there is one. not sure what the guys name is, but look on my350z. he is in texas.
Daniel
screw the GTC's. Maya RT5's now!!!
Old Oct 12, 2004 | 04:42 PM
G-Mann's Avatar
texas that is awsome,i am in texas and i will be getting the greddy tt kit when i go FI(will be a while though)
2004 coupe
blk/blk 6mt
aero kit
no nav
Old Oct 13, 2004 | 04:40 PM
GMADD's Avatar
I have the Arias pistons (9.0:1) and the pauter rods both on order.
If I get the Greddy kit will I need to change or add anything else ?
I might send my TC to Edge for an upgrade but not sure.
Tasso-
Old Oct 13, 2004 | 09:19 PM
SFLG35's Avatar
FGC President
you will prolly want a valve body upgrade as well with that tc upgrade. there are several things that can be done to increase your numbers. one thing you will want to look into with that tc upgrade is a tranny cooler now cause it is goint o run hotter. on the subject of cooling you might want to look into other ways to cool your car off more.
hopefully other will chime in here cause i dont know too much about the subject and need to do somemore learning myself.
Daniel
Old Oct 13, 2004 | 09:53 PM
GMADD's Avatar
Thanks Daniel
as for the valve body, does only Stillen have that option ?
and I'll look into that tranny cooler as well.
Thanks !
Old Oct 13, 2004 | 10:12 PM
SFLG35's Avatar
FGC President
stillen makes one as well as (i think) level ten. check out gspot35's group buy on both of them on my350z.
Daniel
Old Oct 14, 2004 | 01:04 AM
GMADD's Avatar
Thanks !
Old Oct 14, 2004 | 02:58 AM
jdove's Avatar
If you intend to get payback in power from the lower CR you will need to raise the boost. If you raise the boost beyond ~8psi you need to upgrade the base Greddy fuel system (ie. larger injectors and high flow fuel pump). A BOV is also a needed to safely vnet the higher boost. And of course the commensurate re-tune. If you don't intend to raise the boost then you shouldn't be dropping the static CR.
Old Oct 14, 2004 | 03:42 PM
GMADD's Avatar
I want to boost it 7 - 7.5 psi
more boost would be better but not sure about the auto tranny keeping up to that much power.
Old Oct 20, 2004 | 10:47 AM
GMADD's Avatar
Will I need to upgrade the fuel pump if I don't go more than 7psi ?
Old Oct 24, 2004 | 08:48 PM
TXREFI's Avatar
Right now I am running 7 pds, about to add Walbro pump and return line so I can raise to 8 - 9 lb range.
<font color=black>2003 G35 Coupe, Blk/Blk</font color=black>
<font color=red>Frisco, TX</font color=red>
TXREFI G35
Old Oct 30, 2004 | 10:57 PM
GMADD's Avatar
How is the shifting in auto at WOT ?
Does it shift like normal or at redline ?
Tasso-
Old Nov 1, 2004 | 08:59 PM
ChromiumBlue's Avatar
just use the manual shift mode.
I've searched around and there isnt a kit that can even hope to touch the price of a GReddy. I mean I hear there are some defficiencies in the kit but with the money u save I'm pretty sure they are easily fixable and even with installation it comes out cheaper than the APS or PE Kit. They have superb quality but I dont think the GReddy is that much less. But if there are some really bad issues with the kit, please list.
mikemf8
Sep 3, 2015 08:01 PM
UT G35
Sep 3, 2015 03:58 PM
pasjr1972
Sep 1, 2015 10:17 PM
