Nismo G Engine Build
Old Jan 25, 2011 | 12:35 AM
Nismo G's Avatar
To give you a bit of history i previously owned a 2003 G coupe. It was an automatic so as much as i wanted a boosted it i just didn't feel right boosting an automatic. Finally sold it and just recently picked up another 2003, but this time a 6speed. So i have been dying to build a motor and boost it.
I ended up doing a motor swap on a buddies G35 and he let me keep the motor in exchange for the swap. I don't have much time to work on it since i am still in college and work full time as well so i am doing a little bit every couple nights. So i figured i would start a thread with the progress of the motor build.
The motor is going to have a fully built bottom end (main and rod bearings, head and main studs, pistons, rods, and balanced). I am still debating on the heads, since i really am not aiming for huge HP numbers (450-500whp) i think i can save a couple grand by leaving the heads stock. I am pretty open to suggestions so if you have any ideas or tips that are helpful i would appreciate it!
I will keep this post updated with pictures as i go and also post them through out the thread...sorry for the iphone pictures
The engine on the stand before it gets ripped apart.
Took the pulleys and valve cover off
Took the oil pan, crank and outer timing cover off
Old Feb 10, 2011 | 11:03 PM
Nismo G's Avatar
Little update. Finally got some school work out of the way and had some time to play. Got the rear timing chain cover, cam brackets, and cams off.
Got a little something in the mail
Old Feb 10, 2011 | 11:14 PM
lsmooth81's Avatar
Nice, subscribed.
Old Feb 10, 2011 | 11:32 PM
Canadian's Avatar
Canada, eh?
Nice job. Why Turbonetics? Besides stillen from what I've seen it's the worst FI for a built motor.
Old Feb 13, 2011 | 09:13 PM
jsm002's Avatar
Subscribed
Old Feb 14, 2011 | 12:08 AM
Nismo G's Avatar
Saved a few grand by going with a single. If i do end up looking for an upgrade i will look into a GTK turbo later down the road. Like i said before though I'm not really going for huge numbers. I just want to build something that is quick for the street and i know can handle the power without blowing the bottom end out.
Old Feb 14, 2011 | 05:39 PM
dj codeman's Avatar
i thought u were going NA??? Now you're just goin BEAST MODE
Old Feb 14, 2011 | 06:25 PM
Nismo G's Avatar
lol yeah i have a hard time making up my mind.
Old Feb 15, 2011 | 12:31 PM
ymfromon41's Avatar
subscribed
Old Feb 19, 2011 | 08:00 PM
Nismo G's Avatar
Some more progress. The heads and upper oil pan are off. Pistons and rods are out.
poktanG35
Engine - Exhaust
Oct 26, 2015 03:32 AM
linedr89
Aug 17, 2015 05:11 PM
Team STILLEN
Aug 10, 2015 08:17 PM
