vortech fmic replacement
Old Aug 9, 2011 | 05:26 PM
REDG35DRIVER's Avatar
Can you replace the vortech fmic w an larger fmic? has any 1 done this im about to buy a used kit and the fmic just looks like **** i wanna replace it and just wondering if it would be benificial or hurt . . . any thoughts on this?
Old Aug 10, 2011 | 01:35 PM
Dan@Assaultech's Avatar
You can for sure. Some people use the Garrett core when running a T-Trim. If you would just like the same core that comes with the kit that is possible too. Give me a call or shoot me a PM if you want some pricing.
Old Aug 10, 2011 | 05:15 PM
whats the difference in the core? and its a v2 non rev kit i dont know what the t-trim means (first time going FI) would it mater if i got a universal fmic as long as the two inlets match up the same length. .
Old Aug 11, 2011 | 06:52 AM
cchaorule's Avatar
i would like some details on the garret core as well.. what are the dimensions of it'.. thaksss
Old Aug 11, 2011 | 12:34 PM
http://www.atpturbo.com/mm5/merchant...egory_Code=INT
"600HP Garrett high density/high efficiency bar and plate intercooler with ATP cast end tanks. 24" Wide - 10.5" Tall - 3.0" Thickness. 2.5" inlet and outlet hose connections. "
T-Trim is just a higher flow supercharger, you would be fine with Vortech supplied IC. They are around $400
Old Aug 11, 2011 | 10:19 PM
ratm68's Avatar
There are a few generic I/C out there with a 22x8x3.5 core. This is simple going to be approx 2" longer than stock I/C. you can get CXRacing ones which sells on ebay for pretty cheap. Treadstone's TR8 is probably also a generic one, but they do sell a 24x8x3.5 I/C, which will probably fit if you just cut the pipes down an inch or two on each side. I've been considering the TR8 myself.
http://www.treadstoneperformance.com...R8+Intercooler
Old Aug 12, 2011 | 08:54 AM
Treadstone is cost effective as well. We sell Treadstone and will give you a bit off if you call in the order. Support a vendor
http://www.assaultech.com/treadstone.../i-407190.aspx
Old Aug 13, 2011 | 11:35 PM
binder's Avatar
look on my350z.com FI section
the resident vortech guru (oldman350z) has a thread about a new fmic he is using with the results. Search for his name or look in FI for his thread with pics.
I think it was a very good priced intercooler also.
Old Aug 25, 2011 | 03:31 AM
threatcon07's Avatar
If you are running a stock Vortech tuner or full kit, the Vortech FMIC is more than adequate for your needs.
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
Tukeeg35
Sep 27, 2015 12:16 AM
usingthejohn
Media Share G35 Sedan V35
Sep 17, 2015 11:37 AM
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
