06 G35 turbo issue
Old Sep 13, 2011 | 09:32 PM
Eno's Avatar
Eno
http://my350z.com/forum/forced-induc...ine-light.html
Upping your idle revs appears to be a common solution.
Old Sep 13, 2011 | 09:50 PM
lucid215's Avatar
ill try that and see what happens
Old Sep 13, 2011 | 10:12 PM
lucid215's Avatar
juat doesnt seem like my throttle body is operatin right and i just bought this one
Old Sep 14, 2011 | 12:27 AM
Eno's Avatar
Eno
Hope the damage hasn't already been done...
Old Sep 15, 2011 | 12:50 AM
1hotvq's Avatar
Originally Posted by lucid215
changed maf and it got a bit better but still havin idle issues
your idle will always be a bit higher with this kit. its how it is.
starts at about 2000 then after 30 sec slowly goes down to just over 1000.
Old Sep 17, 2011 | 12:29 AM
lucid215's Avatar
got it runnin pretty good with a base map for the tn kit but now it runs hella lean under any amount of boost.
Old Sep 17, 2011 | 12:34 AM
lucid215's Avatar
i got the base map from treadstone since no one else wanted to help. talked to a few shops that i wont name and was told they would help but never did.
Old Sep 17, 2011 | 10:20 AM
1hotvq's Avatar
^ all a base map is good for IMO is to get the car running. youre going to need a custom tune for sure. a good tuner should be able to do that in a few hours for a conservative tune , but if you want to get more out of it it will take longer.
i wouldnt be pushing the car into boost if its running really lean.
Old Sep 17, 2011 | 06:46 PM
herrschaft's Avatar
^+1
A custom dyno tune will yield more power and will be safer for the engine.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
ClwMike
Jul 23, 2015 12:55 PM
LuisGee
Forced Induction
13
Jul 22, 2015 09:15 PM
Chattzx
Jul 17, 2015 11:23 AM
