GTM Turn Key Twin Turbo Kit: Good or Bad
Old Nov 4, 2011 | 11:56 PM
  #31
th3G5pot's Avatar
Ok so what you are trying to say is go twins. I can get the same affect, low rpm's no boost and high rpm's boost after picking the right size turbo or go with a bigger turbo if I want single.
Old Nov 7, 2011 | 12:54 PM
  #32
wbama387's Avatar
Yes the bigger the turbo the later you will build boost. Why do you want to build boost late?
Old Nov 7, 2011 | 08:17 PM
  #33
th3G5pot's Avatar
Its not that I want to build boost late. I just want to stay out of boost while just driving normally. I know that if I just drive really nice than I won't build boost. I just want to build boost around 3k rpm because I usually never run the car to 3k when I am driving normally.
Old Nov 7, 2011 | 08:26 PM
  #34
350Z T's Avatar
Originally Posted by th3G5pot
I don't think I want twins now. I was thinking momentum performance single turbo kit now. I want to run a single because I want to boost at high rpm's instead of low rpm's. The car would also be a daily driver and I've heard its better to run single on daily driven car. Any body know anything about the Momentum Turbo kits for the G35 with the Garret GT35R.
I don't think you know what you want.. and I don't think you understand how a turbo system works, making this a dreamer thread.
Old Nov 7, 2011 | 09:30 PM
  #35
herrschaft's Avatar
A turbo needs a certain amount of throttle to completely spool and hit full boost, under "normal" driving conditions this will not happen. And by normal I mean driving like a grandma.
Old Nov 8, 2011 | 10:40 AM
  #36
th3G5pot's Avatar
Maybe I'm not asking the questions or explaining it the right way. I think I have enough info now to choose a kit that I want. Thanks to all.
Old Nov 8, 2011 | 11:00 PM
  #37
wbama387's Avatar
Too meany dreamer threads. Do research there is a lot of info here that will answer these simple questions. If you are lazy just call a shop they will be more than willing to give you all the info you want.
chinee
Jun 10, 2024 07:48 PM
Jusseth
Sep 13, 2020 12:25 PM
hdmark
Apr 29, 2019 04:31 PM
bTanz
Oct 15, 2015 02:31 PM
