Spark Plug Gap for FI?
Old Apr 24, 2012 | 12:55 AM
josh.irvine.6's Avatar
I have an 03 G w.Turbonetics kit, I have the 1 step colder plugs in my car right now, but I did not change the gap on them when they were installed which is .44. Is there a specific gap I should want? I'm running between 8 and 10 psi of boost. Thank you for the help.
Old Apr 24, 2012 | 02:28 AM
o__O's Avatar
You want to run largest gap without spark blow out. If you're not having problems at the moment then leave it alone
Old Apr 29, 2012 | 08:47 AM
How do I know if I'm having problems or not. My numbers from the dyne run were low.. could this be part of the problem possibly?
Old Apr 29, 2012 | 09:35 AM
freakta's Avatar
could be a million other issues... but you would know spark blow out missfire and all that if you were gapped too big. when you get all the other issues figured out then id play with spark plugs to tweak everything, until then if it works dont worry about it
Old May 1, 2012 | 02:52 PM
str8dum1's Avatar
you dyno would look jagged as hell if you had blowout. You'd be misfiring, exhaust popping, etc
jeffbdye
Jun 1, 2018 03:51 PM
g.spot
May 9, 2016 10:54 PM
KallDay86
Jan 8, 2016 12:42 AM
BfloG35
Audio/Video/Electronics
Oct 16, 2015 05:22 PM
Patrick Bovee
Oct 1, 2015 10:42 AM
