Questions about using the stock MAF on turbo'd G35?
Old Dec 26, 2013 | 12:40 PM
  #31
GTR203's Avatar
Just had my single turbo setup tuned by rdz and maxed my stock maf out at 380whp at 9.8 psi. They claimed with an uprev maf I should be good for 440-450 wheel. This was a mustang dyno btw
Old Dec 27, 2013 | 09:57 AM
  #32
rcdash's Avatar
I ran my stock MAF along with a MAP set up for a long while. The MAF would peg out at 5 volts when the MAP was near 6 psi. You have a few options to monkey around with the stock MAF - increase the size of the tube the MAF is placed into, narrow the hole exposing the thermisistor, or add a fixed resistor in series to keep the voltage below 5 volts as the air flow increases.
I always wondered why someone didn't just tap the MAF wiring but insert a MAP sensor, temp sensor and retune... I think it would actually cost less and work better than a new high flow MAF.
R350k5
Oct 1, 2015 08:41 PM
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
laksjd84
Jul 24, 2015 05:12 PM
Chattzx
Jul 17, 2015 11:23 AM
