Only half boost :(
Old Dec 30, 2013 | 01:18 PM
lack23's Avatar
Only half boost :(
So Im only getting about 5 psi.. very depressing. Accelerates hard but in high rpm it just doesn't seem like the supercharger is doing much. I've been told my gauges are **** and they are not accurate. Glow shift gauges.
What I gotz:
deatschwerkz injectors, walbro fuel pump, transgo valvebody, uprev tune, fd lvsd swap, MD ART pipes.
Any thoughts? boost leak?
Old Dec 30, 2013 | 01:52 PM
herrschaft's Avatar
A boost leak should be easy to check for on a supercharger, start there first.
Old Dec 30, 2013 | 01:57 PM
bigc's Avatar
Wings Nation
you need to tell us what supercharger kit and what size pulley you have installed.
generic answers: tighten your serpentine belt and check/re-tighten all couplers.
Old Dec 30, 2013 | 02:05 PM
lack23's Avatar
V3 stock pulleys
Old Dec 30, 2013 | 03:03 PM
bigc's Avatar
Wings Nation
the stock vortech pulley is different if you have non-revup (3.33") versus a revup (3.12"). what boost did you hit during tuning? what power level?
Old Dec 30, 2013 | 03:16 PM
seymore4's Avatar
m56
Did you try unplugging your console and plugging it back in? Your Xbox seems to be malfunctioning
Old Dec 31, 2013 | 03:57 PM
ratm68's Avatar
i had my bypass valve crapped out on the vortech resulting in boost only holding at 5lbs. If your car is still pulling after the gauge stops at 5, then it's the gauge, but if it hits 5 and your car feels like it stop making power, than you have a leak somewhere.
g.spot
May 9, 2016 10:54 PM
mbe32
Nov 13, 2015 11:09 PM
ncg35guy
Sep 24, 2015 04:53 PM
