Vortech Supercharger for 5AT
Old Jun 17, 2012 | 02:19 PM
thisiswang's Avatar
Searched high and low, over and under but can't find any good info on the subject.
Can the vortech S/C be installed on an 07 G coupe 5AT? on their site they say the 07 sedan 5at needs to be modified for mechanical fan but no info on the coupe. any input and insight would be appreciated.
Old Jun 17, 2012 | 03:48 PM
Modifying bauss's Avatar
Also can it be done on a 05 g35x sedan 5AT sedan? I called vortech and they couldn't even give me an asnwer.
Old Jun 17, 2012 | 05:53 PM
G35 Dream's Avatar
I would thank that if it is compatible with a 06 5MT it would be for a 07. There are no differences in those years for the coupe.
Old Jun 17, 2012 | 05:57 PM
G35 Dream's Avatar
But if a company can't even give an answer on what cars it works on I'm not too sure I'd want it anyway.
Old Jun 17, 2012 | 06:01 PM
Shanes_G's Avatar
the only thing different is the tranny. did you contact the makers of the supercharger yet?
Old Jun 18, 2012 | 12:39 PM
ibelonginprison's Avatar
Resident G35Driver Pirate
The reason the company may or may not know what it fits is they haven't personally worked with that car. If they haven't seen the differences between the 06-07, then how would they know? Better to say "we're not sure" than say "oh, yeah, why not... sure it'll fit."
I would assume the 06-07 are the same for the G coupe.... very few changes between these years, none at the front of the motor that I'm aware of. But, you might want to ask some other 5at 07 owners and see what they say. That's where I would start. As long as the radiator, fans, and all the bolt patterns/pulleys on the front of the block are the same as the '06, there shouldn't be too much else to worry about. That's where all the piping runs, and the blower bracket(s) bolt.
You can also double check things by looking online at parts catalogs and making sure things like the water pump, belt size, and oil pan/oil pan gasket size are the same between 06-07. Those would be my two biggest concerns if I was unsure about it all.
Old Jun 18, 2012 | 12:43 PM
Silencer_0's Avatar
I have the Vortech V3 on my 07 5AT. It was an easy install. Just specify that you have the DE motor, not the REVUP.
Old Jun 20, 2012 | 06:48 PM
MrSnakeaholic's Avatar
will vortech v3 fit a 2004 coupe 5AT
hello i'm new here, will a vortech v3 bolt on fit on a G35 coupe 2004 5at?
thanks
Old Jun 20, 2012 | 07:02 PM
thisiswang's Avatar
thanks
yes it will, however after a lot of research... your tranny will hate you. you may need to install the transgo shift kit or get a really good tune.
Old Jun 20, 2012 | 07:03 PM
thisiswang's Avatar
it will fit but only with customizations of the kit that can become expensive
Old Jun 20, 2012 | 11:39 PM
thank you, for your fast response, ok i will first get all the bolts on and tune, and then the charger, but will Osiris standar handle the vortech? with the transgo?
Old Jun 20, 2012 | 11:50 PM
herrschaft's Avatar
^Yes
Old Jun 21, 2012 | 08:32 AM
thisiswang's Avatar
you're also going to need upgraded fuel injectors and pump
Old Jun 21, 2012 | 10:05 AM
No, what he needs to do is a lot more research on this forum, and this forum: http://my350z.com/forum/forced-induction-182/
95% of your questions can be answered by a search, and about an hour of reading.
Old Jun 21, 2012 | 11:24 AM
thisiswang's Avatar
i'm sympathetic cuz i'm the OP but there really isn't a lot of information on the auto tranny version
