Going on a road trip, Only 91 oct Available.
Old Jul 4, 2012 | 01:40 PM
ReStylin's Avatar
I am leaving on Monday to go out east for a few weeks to enjoy myself, I am taking the G.
So, herein lies the problem, once I hit New Brunswick, I will ONLY have access to 91 Oct Gas.
My Uprev tune on my Single Turbo Momentum is for 94.
Touelene is readily available across canada. Can I mix this with 91 to create a Safe 94?
http://www.elektro.com/~audi/audi/toluene.html
I cant go 2 weeks driving my car without going WOT lol, Its out of the question. LOL
Old Jul 4, 2012 | 04:53 PM
superchargedg's Avatar
It will raise the octane rating but i dont know what the proper mix would be.
Old Jul 4, 2012 | 05:26 PM
Dsskyline's Avatar
look into this subie and evo guys swear buy this stuff if race gas is not available.
http://www.google.com/url?sa=t&rct=j...P5gHBw&cad=rja
Old Jul 4, 2012 | 07:27 PM
seymore4's Avatar
m56
You'll be fine with 91 octane, just stay out of hard boost. That 35R shouldn't spool that quick so it won't be hard to drive without boosting all over if the drivers up to the challenge
Old Jul 5, 2012 | 01:28 PM
ReStylin's Avatar
Yes, I know its not hard to drive out of boost, but if I cant drive hard, then Ill just rent a camry or something. haha
Old Jul 5, 2012 | 01:41 PM
Eno's Avatar
Eno
You ever get those issues ironed out?
Old Jul 5, 2012 | 02:11 PM
ReStylin's Avatar
No, Ive been driving my Lambo or my SL65 lately.
Old Jul 5, 2012 | 04:07 PM
str8dum1's Avatar
why doesnt your knock sensor work? the stock ecu will pull timing if it knocks. you will know if you are pinging as well.
just run wastegate pressure and you will have no issues.
Old Jul 5, 2012 | 04:32 PM
Texasscout's Avatar
Found this with a google search
How much toluene should I use per tank of gasoline?
A 5 or 10% increase in the aromatic content of gas will most likely be well within the refining specifications of gasoline defined by ASTM D4814, which specifies an aromatic content of between 20% and 45%. What this means is that if the 92 octane gas that you started off with had an aromatic content of say 30% and you increased it by 10% to 40% you would still be left with a mix that meets the industry definition of gasoline.
Because toluene is such an effective anti knock fuel it also means that it is more difficult to ignite at low temperatures. The Formula 1 cars that ran on 84% toluene needed to have hot radiator air diverted to heat its fuel tank to 70C to assist its vaporization. Thus too strong a concentration of toluene will lead to poor cold start and running characteristics. It’s recommended that the concentration of toluene used not to exceed 30% or what the engine is capable of utilizing. i.e. Experiment with small increases in concentration until you can no longer detect an improvement.
Octane ratings can be very easily calculated by simple averaging
Toluene has octane rating of 114. So use this formula to figure what octane you get when u mix toluene with gasoline:
Litres of gasoline x Octane (eg.95 or 98) + (Litres of toluene x 114)
Total Litres of Gasoline & Toluene
example
The fuel tank capacity of an EVO 8MR is 55 litres. Based on a 30% toluene mixture, filling it with
16.5 litres of toluene and 38.5 litres of 98-octane gasoline will yield a fuel mix of:
(38.5 litres x 98) + (16.5 litres x 114)
55 litres
= 102.8 octane
Notes: Common ingredient in Octane Boosters in a 12-16 ounces bottle will only raise octane by 0.2 - 0.3, i.e. from 98 to 98.3 octane.
MAKE YOUR OWN OCTANE BOOSTER
To make your own octane booster, it is easiest to make up a large batch, and then bottle it up in "dosage-size" uses. Below is the basic formula of one of the popular octane booster products. To make eight 16 ounce bottles (128 oz = 1 gal):
100 oz of toluene for octane boost
25 oz of mineral spirits (cleaning agent)
3 oz of transmission fluid (lubricating agent)
The above formula is an "octane booster with cleaning agent and lubricating agent”. Diesel fuel or kerosene can be substituted for mineral spirits and light turbine oil can be substituted for transmission fluid. Color can be added with petroleum dyes.
http://www.best-chemical.com/racing.htm
Old Jul 6, 2012 | 01:06 AM
Sylvan lake V35's Avatar
This is the reason I am tuned on 91....i can always easily find it
Old Jul 6, 2012 | 11:24 AM
deanfootlong's Avatar
so rent the camry. problem solved.
Old Jul 6, 2012 | 01:09 PM
ReStylin's Avatar
Nah, Ive decided to take the Gallardo.
Old Jul 7, 2012 | 02:22 PM
tylerxfire's Avatar
seriously..
Old Jul 7, 2012 | 02:46 PM
ReStylin's Avatar
Ya, or the SLK 55 AMG
Old Jul 7, 2012 | 03:23 PM
herrschaft's Avatar
That Gallardo looks stock, if so please lean forward so I can smack you
