Vortech Rev-Up Serpentine Belt Replacement
Old Aug 28, 2012 | 07:47 PM
dvandriesen's Avatar
Bought some replacements for if the front belt breaks just curious i had to undo the SC from the bracket to actually squeeze the belt in between SC and the bracket. Is this necessary can you actually squeeze the belt in-between or must you loosen the SC from to allow the belt to fit?
Old Aug 28, 2012 | 09:55 PM
AreSicks's Avatar
I managed to squeeze mine in without taking anything off. Get the belt started in the opening and turn the pulley as you push the belt through the gap. It will feed itself in with a little effort.
Old Aug 29, 2012 | 07:16 AM
Thanks definitely need to use a little force it looks. It's a tight squeeze.
Old Aug 29, 2012 | 07:49 AM
AreSicks's Avatar
Yep! It will go though. Main key is to turn the pulley little by little as you put pressure on the side of the belt.
Old Aug 29, 2012 | 09:23 AM
Alright sounds good wasn't sure I just undid the back bolts from sc before mounted it. This mainly for on the road. Figuring out what tools to keep in the trunk.
StreetStandard
Engine-Vendor
117
May 22, 2020 08:21 AM
Tukeeg35
Sep 27, 2015 12:16 AM
Tukeeg35
Engine - Intake/Fuel
Aug 21, 2015 04:19 PM
G35Sask
Aug 1, 2015 11:16 AM
