which turbo kits??
Originally Posted by newtlicious
I love you Peter. My only decision now is whether to go for max HP with an 8.5:1 CR or shoot for lower HP and a fatter curve with a 9.5:1 CR. There is a 350Z tuned by SGP racing in Houston that made 619whp with 8.5:1, Greddy snails and some tomei cams at 17.5 psi.
Do you think 500whp is attainable safely with 9.5:1 slugs and stock cams?
I would like to tune with 91 octane even though 93 is available here. That way I can run 93 all the time and not have to worry about getting a bad tank of gas or not being able to find 93 when I travel.
So how about it, is 500whp, 9.5:1CR, 91 octane and stock cams possible with some good old SGP tuning?
Thanks
Peter
Originally Posted by g3po
the APS kit for G will most definately not be CARB approved athe the time of release in ~May. However; like the Z kit ,APS has . will pursue CARB approval. Whether it is obtained is a risk some may need to consider. Peter if you are reading this , I hope you still hold true to earlier committments to seek CARB on both Z and G platforms...
Thanks
Peter
I reckon go for the higher comp ratio ( 9.3:1) and develop a nicer power curve across the entire rpm range, improved off boost partial throttle power also with the higher comp ratio
Gurgen
Originally Posted by aps
damen good things come to all that are patient.
Peter
Peter
It's been said many times, just because the JWT kit is targeting 400hp to the crank doesn't mean that's all it will push. They claim that around 330ish to the wheels is the safest to run the car for a long time. So if you want to build the motor they said they would have reflashes to turn up the boost. So don't count them out just because you hear 330 to the wheels.
boostelevator
Engine - Power Adders
Sep 9, 2015 05:56 PM
