Supercharger,Twin Turbo,Single Turbo?????
Originally Posted by DELOCK
What are the pro's and con's?
The first upgrade I want to do is performance. So I would like everyone input on what is what................
TT- pros: High torque. cons: turbo lag, not safe over 7psi on stock internals (see pro for reason)
it really depends on how much money you want to put into it. You can makeit a daily driven car with a TT, but you'll need a lot more parts to make that a safe choice. I daily drive my Vortech'ed G hard and it hasn't given me any problems...so far, I have 5k miles on the system.
Originally Posted by Randys_G
SC - pro's: safer on engine, power available immediately. cons: doesn't produce as much torque as TT, belt driven
Hope this helps.
Peter
From what I learnt over many years of working with FI you need the exact same parts to make a supercharged or turbocharged engine a safe daily driver, (both forms of FI have to cope with positive pressure and higher cylinder pressures) in reality the fuel system and engine management ignition timing control is critical on both types of FI.
Peter
Originally Posted by aps
SC being a safer FI option is not absolutely correct, in fact at the identical WHP the turbocharger would be safer as the SC would need to produce at least 40 Hosrepower more at the cranshaft to produce the same power at the wheels as a turbochrged engine.
Turbo lag is virtually an issue of the past with the introduction of modern dual ball bearing turbos, Duall Ball Bearing Twin Turbos will generally produce a stronger torque curve across the entire RPM range (much stronger than a centrifugal type of SC) than that of a positive displacement or centrifugal supercharger and at no higher risk to engine safety/durability.
Hope this helps.
Peter
Hope this helps.
Peter
Correct, except you forget the fact that the turbo makes more torque and it's the torque that breaks things
APS, I think that TT of yours is sweet, don't get me wrong, but that's how I feel as far as safer goes.
Thanks
Peter
what all of you FI geeks do about warranty? just say - fcku it? I a crious because I don't want to spend 10+k on SC or TT and then have something minor/major happen to the car and not being able to take it to the dealer for service. Would you ONLY suggest TT SC in case if you know howto work on your own car or what?
tnx
tnx
To go FI ask yourself a couple of questions:
1) Do I have the money to buy the FI?
2) Do I have the money to buy a new motor if this one fails?
Supercharger vs. Turbo:
1) Is 330 - 400 (pushing it - imo) whp all that you need, then a supercharger may be right for you.
2) Does a whine coming from the engine bay bother you, then a supercharger may not be right for you.
3) Do you have a sizeable amount of money to spend on the motor, then Turbo charging would be the way to go (imagine 600 hp - damn).
I have a supercharger and have about $6500 invested in the whole setup: s/c, install, guages, tuning, ect. Probably will spend about $500-600 a year on tuning.
If I blow the motor, I would probably replace motor and return to stock and go a different route, but that's just me and that's why I chose a supercharger.
On any FI setup tuning and understanding what you are doing to the motor are crucial. I am still learning and forever will be.
I too was once hung up on the warranty thing. I debated back and forth with myself and finally said "WTF". I just didn't want to go to the grave and had never been Force Induced!
Sorry for the rambling, just some of my thoughts.
Good Luck
Good Luck
If 330-400 whp gain is acceptable, then why not the Stillen SC stage 2 kit. No tuning required. You get a 3yr/36,000 mile warranty on engine. Plus its Carb certified. Dont have to worry about getting pulled over for cops to check under your hood. Well, I guess its that freakin stillen hood thats preventing me from buying it. From what Ive heard Stillen is coming out with a new style hood for the SC kit, but no pictures yet.
The hood blows, but it looks kind of cool in black.
