Engine compression and psi variance...
Old Aug 4, 2014 | 11:03 PM
josh.irvine.6's Avatar
I'm just looking for some insight on the amount of compression ratio in a cylinder and what lowering it for FI does in terms of PSI. If stock compression is 10.3:1 for a 2003 engine - what would it have for a compression test rating in PSI? As we drop the compression ratio in a built motor for FI down to 8.8:1 - what is the expected PSI in this range for a healthy newly built engine. In between these ratios is there a consistent drop in PSI per engine? Thank you, appreciated.
Old Aug 6, 2014 | 06:00 PM
Anyone?
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Joe Gargano
Sep 18, 2015 11:17 AM
yosip1115
Sep 9, 2015 03:30 PM
