JWT TT 700bb Dyno Graphs
Old Aug 14, 2014 | 09:23 PM
josh.irvine.6's Avatar
I've been looking around and I can't seem to find any more then 1 or two 700bb dyno results on here. Lots have people have discussed their numbers but the curve is rarely shown - and the one I saw seemed like a bad tune, with a bad curve... not sure if this should have been here or the dyno/tune section.
Please share some if you can dig them up - thanks!
Old Aug 15, 2014 | 12:18 AM
Sylvan lake V35's Avatar
I don't have any graphs but I have driven a few, they pull early and hard. They spool about 500rpms after the 530bb kit does if I recall right.
Old Aug 22, 2014 | 05:38 PM
That makes sense to me. The only graph I've been able to come across can be found at:https://g35driver.com/forums/forced-...o-numbers.html
It just seems to me that the 700 bb that they have there, seems to be a pretty late power curve... Is this just a tune issue? Or is this to be expected.. the 530's is completely different...
Old Aug 23, 2014 | 10:44 AM
GaryEvans's Avatar
The area under the 530 curve shows it to be a good street application and it puts out more power until 4000rpm. If your racing and keeping it over 4000rpm the 700 would be the best bet but will also require other engine mods to support it. The JWT 530 kit can be used on a bone stock engine.
Old Aug 23, 2014 | 07:41 PM
Thank you for the info. I'm buying a 700bb kit from another user as well as having a stage 2 ipp motor so I'll be good to go as far as other mods needed... I've also got a oil cooler, catch can and custom fuel return system for the setup as well so I don't see any foreseeable issues arising anytime soon. I was just trying to get an idea of what the curve will look like and didn't know if the picture above is typical of the kit.
Old Aug 23, 2014 | 07:55 PM
N8Deezy's Avatar
Here's my graph. as you can see with the dropoff. limiting factor was the injectors at the time of the pull. (460cc) JWT BB700 kit. twin intercooler, garrett GT28RS .86 A/R turbos.
Old Aug 23, 2014 | 11:04 PM
Thanks for getting this up here - I just need some clarification on what I'm reading though. Is this 2 separate runs, the left side showing the torque of run 1 and 2, and the right side showing the hp of the two runs? What was the boost for run 1 vs the boost levels that were final with the higher numbers? Much appreciated.
Old Aug 23, 2014 | 11:49 PM
N8Deezy's Avatar
Yes. It's 2 pulls. 1st pull is 10psi and 2nd pull I believe is at 13 or 14psi. They wanted to charge me extra to put a sensor in my exhaust and I called bs but I def recall baseline being 10psi. (Boost controller reads each boost)
Old Aug 24, 2014 | 09:15 PM
Makes sense to me.. What exhaust were you using? Did you ever get bigger injectors and tune all the way?
Old Aug 27, 2014 | 12:58 AM
N8Deezy's Avatar
I was running a stillen true dual. Ended up goin with a GTM kit, bigger turbos, fuel system. The whole shebang haha.
seagrasser
May 3, 2022 09:43 AM
Video Share
Jan 31, 2017 04:00 PM
Red G Coupe
Tuner & Dyno
Jan 14, 2016 01:13 AM
atomevolution
Engine - Exhaust
Oct 12, 2015 01:00 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
