Haltech Boost Control/ Multiple Maps
Old Aug 31, 2014 | 10:37 PM
josh.irvine.6's Avatar
I'm in the process of doing a build and I've got the Haltech unit in my car and will be using the Haltech manual boos controller.
My question, is there a way to have two different boost levels without needing to use a laptop to load another map? Or even 3 levels? Can I use some type of toggle switch in the cabin and switch it to a different level from there?
Thanks.
Old Sep 2, 2014 | 09:46 PM
Bump..
Old Sep 9, 2014 | 09:05 PM
ge35es's Avatar
Thanks.
yes....
put a 5 or 10 psi spring in your waste gate and run an off/off switch to your boost solenoid.
Switched off it runs the spring rate in the waste gate.... switch on it runs what ever your controller is tuned for above the waste gate spring rate
Old Sep 11, 2014 | 10:01 PM
Awesome, thank you. What option would I have for selecting different boost outside of stock and one other.. Is there a trim dial or rotary design I could use?
Or am I limited to just those options?
g.spot
May 9, 2016 10:54 PM
ncg35guy
Sep 24, 2015 04:53 PM
