how effective is the intercooler on a vortech kit ?
Old Nov 10, 2014 | 08:03 PM
ge35es's Avatar
How effective is the intercooler on a Vortech full Kit ?
the reason I ask is that everything Ive read and my personal experience with intercooling
seems to indicate
1) it is really obstructed with a stock bumpered G35 and not right out in the air flow.
2) its not shrouded so most of the air flow will go around it rather than through it
3) not sure what the size is but with the 12 sq in per 100 hp rule of thumb it would need to be 4 square feet in area minimum.
has anyone actually measured temperature drop at 60mph (100kph) ?
Im sure it must be dropping the IATs but if properly set up it could do so much more.
Old Nov 10, 2014 | 08:07 PM
bluedevils95's Avatar
I think my kit is ok. I have seen bigger ones (or should i say upgraded) and they said that they notice the differences in temperature and performance. The one they give you is small and thin and just gets the job done. It works for my everyday driving.
Old Nov 19, 2014 | 10:43 PM
epborden's Avatar
The intercooler is fine for the power numbers you will get. If you have a coupe you could always upgrade the bumper to a kuruma. If you have a sedan you could try the '03, AWD, or kurookie bumper. I have an X, so the AWD bumper, and I haven't had any issues with the temp. The little opening passes air onto it although the surface area is small it gets it from the sides too. Regardless of direct airflow the intercooler will still radiate heat outward.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
linedr89
Engine - Power Adders
Oct 4, 2015 07:29 PM
JG_G35
Engine - Intake/Fuel
Sep 7, 2015 09:35 PM
n2fooz
Sep 4, 2015 07:46 PM
