Progressive Nitrous Controller
Old Jan 7, 2015 | 05:36 PM
B T's Avatar
B T
Has anyone used the Daytona NC-2 controller? I'm not too sure where to get the tach signal at. It won't read the low voltage signal coming off the Y/R pin 62 and I'd like to tie it in at the ECU. Also, it seems the TPS wire is white on my car, is it green for everyone else?
My setup is as follows:
DynoTune 75 Shot kit w/ 10lb bottle
Auto Warmer
Remote Bottle Opener
Dynotune Nitrous Control Center
Purge kit
Old Jan 17, 2015 | 10:34 AM
B T's Avatar
B T
Looks like the controller input reading the RPM may have been blown, hence no signal. ECU Pin 60 Ign #1 (Y/R) is still the correct wire. On another note, I've got the replacement plugs, but want to wait until I get a working controller and up the shot to install. How dangerous would it be to run the stock plug on a 35 shot (one test) with a base rich nitrous tune? Running 93 E10 here. Testing scheduled for after lunch today.
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
Learned Hand
Oct 1, 2015 09:02 AM
markbilo
Sep 30, 2015 01:33 AM
