Engine Blow up on Dyno - Questions
Old Jul 11, 2017 | 07:49 AM
Justice06RR's Avatar
Originally Posted by rcdash
Cylinders 5 & 6 receives the most airflow. They will be leanest / hottest. When tuning a stock motor, best to use higher octane fuel (not oxygenated so similar AFR as pump gas, e.g. leaded fuel if no cats to worry about).
OEM parts must be kept cool to survive.
There goes that high-octane Premium fuel thing...
Some people will argue that its ok to run Reg on these performance cars.
Sorry to hear OP. I would opt for replacing the engine if possible with a stock one and use your salvageable mods on it. We don't know the full extent of the internal damage so it could be worse. We also don't know the history of your vehicle so that is something you'd have to elaborate (mods, maintenance, fuel, etc).
