how high does the vortech go?
Old Mar 13, 2005 | 02:29 AM
G-Mann's Avatar
i know i have asked this a couple times but i have gotten mixed responses. so, is the vortech supercharger able in any way/shape/or form to get 450+rwhp(w/ beefed internals and fly/clutch) w/ out boring and a stroker kit? what are the pulley sizes and how much hp do they make?
if anyone can answer any of my questions it would be very helpfull as to i almost have the money for it
Old Mar 13, 2005 | 10:38 AM
booger's Avatar
They dont make a smaller cog pulley that goes on the blower .But they make a bigger cog pulley for the jackshaft , and smaller pulleys for the serp pulley . As far as making 450whp hmmmmmmmmm.....you might get close on a Dynojet dyno
Old Mar 14, 2005 | 05:11 PM
G-Mann's Avatar
i thought they made a higher psi pulley for the vortech?
Old Mar 15, 2005 | 10:21 AM
gspot35's Avatar
Here's the problem you run into with s/cer's. When you up the psi it becomes unsafe for the motor. So you think "I'll rebuild it". So if you rebuild it with a lower compression ratio and stronger internals it takes more boost to create the hp you had with stock internals. It really is a catch 22. If you feel you need to make 450hp, DO NOT GET A SUPERCHARGER.(period) The Vortech is only good for about 13psi before it is over spun, not to mention when you run it at that velocity you are blowing VERY hot air out. The stock intercooler is not capable of cooling that much heat. Good luck in your quest for power.
Old Mar 15, 2005 | 05:03 PM
PimpCoupe's Avatar
What's the highest RWHP people have gotten out of the Vortech?
Old Mar 15, 2005 | 05:41 PM
booger's Avatar
I was mistaken when I said they make a 34 tooth cog pulley for the jackshaft . I called Vortech and they dont make a larger jackshaft pulley nor a smaller blower pulley . SO the only thing we can do is go smaller on the serp pulley . IMO going smaller than the 2.87 will result in belt slipping and have to be to tight to work .
Old Mar 15, 2005 | 06:49 PM
gspot35's Avatar
I believe Zimbo got a 32 tooth pulley. I called Vortech a while back to buy a different cog pulley. There is a company who makes the pulley's in Arizona or something. They said if I sent them mine, they could make a smaller size. Didn't persue it.
Zimbo are you still out there??
Old Mar 15, 2005 | 09:04 PM
booger's Avatar
Vortech told me yesterday that they didnt make a LARGER cog pulley for the jackshaft to make more boost . Nor a smaller blower pulley . The 32 tooth is stock jackshaft cog pulley [ pretty sure on that ] , I think the blower is 27 tooth . I remember now that there was some one talking about a 34 tooth one last year . It was a thicker pulley and I think they said they had to get a longer bolt for it . Cant remember if it was Zimbo or not
Old Mar 15, 2005 | 09:38 PM
Gman2004's Avatar
Booger,
It was mcduck. Go here http://www.my350z.com/forum/showthre...h+supercharger
post #17 and #23
Old Mar 15, 2005 | 09:53 PM
booger's Avatar
Originally Posted by Gman2004
Booger,
post #17 and #23
Thanks....Thats what I remember .Gonna look to see if I have the room to put on that 50mm pulley on . I dont know if it can be done or not , but maybe have the shop at work cut it down to 35mm
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
g.spot
May 9, 2016 10:54 PM
the93owner
Oct 4, 2015 09:40 AM
vamarris
Sep 26, 2015 12:56 PM
