Opening up stock bumper for intercooler
I posted a thread in the Body, Exterior... forum with pictures of a simple stock G35 coupe bumper mod that opens up ventilation to an intercooler. The stock bumper is a terrible design for intercooling because about 95% of the front mounted intercooler is blocked. I didn't want to spend the money on an expensive, boy-racer-looking bumper that has less road clearance.
bumper
Originally Posted by DFWG35
Originally Posted by G352NV
Ok this might sound crazy, but Im a little crazy when it comes to modding. BUT cant you go to pep boys and buy two push fans for about 80.00?
fans
Yes you can but the idea is to provide the MAX amount of air possible. The SPAL fans produce the maximum amount of air based on there diameter. More air = cooler SC temps.
How loud are the SPAL fans?
Louder than the OEM fans?
Fans
Let me answer two questions with one post.
Are the fans loud?
Yes if you are sitting still they are somewhat loud but they only activate when A/F drops below 12. So in my case you never hear them.
Controlling the fans..
I am using a DynoJet Wideband commander A/F gauge. It offers output trigger wires that can activate a relay based on A/F rations. I have mine setup to output a ground that triggers a relay that in turn supplies power to the fans. IMO if you did not do something like this the fans would drive you crazy.
Another option would be to purchase a boost activated switch and trigger them at lets say 1 LB of boost.
Example:
http://www.atpturbo.com/Merchant2/me...de=ATP-BCS-003
Are the fans loud?
Example:
Tommy,
What about a programmable RPM switch? (say one that you can adjust through your VDC button?)
That way you set them to come on at anything above 2000RPM (basically when moving) in the summer time and anything above 4000rpm in the winter time (almost never).
IC fans
Originally Posted by KPierson
Tommy,
Unfortunately were heat soak becomes an issue is "after" a boosting event(s) when the car is then idled and air movement is nil. So ideally , if you use IC fans or water spray you want to turn them on in response to an increased hheat differential between "pre IC and Post IC" temps. So what onne needs is a pre ans post thermcouple controling a timed windo switch. That would run the fans "only" when needed.
