Supercharger Kits (Newbies)
Vortech Supercharger Kits
The Vortech supercharging system for the Infiniti G35 will impress you with the obvious attention to detail and fully integrated appearance. Increase your horsepower from 287 to 412 and torque from 274 to 355 ft/lbs at 8 psig
Vortech gear driven supercharger with SQ technology provides nearly silent operation and unmatched reliability
Technologically advanced, high-efficiency impeller and housing design developed in Vortech's supercharger test cell
Fuel management upgrade includes a high-flow fuel pump and fuel management unit for safe, reliable operation
Stand-alone ignition timing control computer for seamless acceleration
Integrated charge cooler configuration allows for additional horsepower gains
Oil feed and oil drain assemblies deliver the best possible lubrication and cooling for the supercharger, even under sustained boost conditions
Discharge duct connections utilize heat resistant silicon sleeves and premium quality stainless steel clamps
High-flow, reusable air filter
Billet aluminum mounting bracketry
Maxflow Race bypass valve provides surge-free compressor operation
Supercharger drive system includes all necessary belts and pulleys
Compatible with factory OBD II engine management systems and 3-year limited warranty
Website: http://www.vortechsuperchargers.com/
Stillen Supercharger Kits
It is also the basis for kits by Jackson Racing, TRD, Rousch and others. This has been designed as a modification that will be reliable, long lived and satisfying in daily use. Before offering this kit for sale, Stillen put 10 intensive months of design, testing, dyno time and day to day driving into it. The kit has been tested over thousands of miles in all driving conditions. They continued to refine it making improvements in operating efficiency, installation and compatibility with existing systems. The kit has been designed in consultation with an approved testing lab for CARB. It is our intention to have this as a 50 state legal kit. Stillen will submit it for final approval shortly. Please contact us for details on the Carb approval as it may apply to your purchase. In CARB trim, the unit produces approximately 60 horsepower to the wheels and upwards of that at the flywheel. This power is delivered in a smooth, linear fashion from idle through redline. We are rating this unit at an average of 354 hp @6000 rpm and 318 ft/lbs at 4200 rpm. We anticipate an average install time of 8-10 hours for a certified mechanic with experience in this type of installation. Stillen has recently received approval from Dell Financial Group to offer their extended warranty. This will allow limited coverage of the engine for 3 years or 36,000 miles as an option. This approval was granted after extensive review of our engineering designs and independent testing of the unit. In the near future, Stillen will be adding optional parts and tuning levels to this kit. There will be parts such as intercoolers and tuning modifications to increase horsepower, torque and operating efficiency. These parts and modifications will be offered for "Off Road Use Only" and their use will invalidate any CARB certification. All foreseeable options will be sold as upgrades to the existing kit. Stillen has worked hard to produce a kit that is state of the art in every way. They have invested in new testing equipment, personnel and tooling. They have produced a kit that is OE level quality or better. The unit requires additional clearance under the hood for the supercharger. There are 5 options to accomplish this. They are as follows: 1. Replacement fiberglass hood. (This is supplied ready for final prep and painting.) Requires truck LTL shipping. 2. Replacement carbon fiber hood. (Requires no painting.) Requires truck LTL shipping. 3. Fiberglass Cowl. Requires a cut out of the stock hood. Supplied ready for prep and painting.
There are also a stage 2 and 3.
Website: http://www.stillen.com/
HKS Rotrex Supercharger Kits
HKS is proud to introduce the highly anticipated HKS Rotrex Supercharger kit for 2003+ Nissan 350Z. This direct bolt-on kit produces a 80+ Horsepower gain over stock (measured at the rear wheels), with boost set to 0.48bar (~7PSI). The supercharger is a centrifugal type that features a unique traction drive, and a closed oil circulation system. The traction drive utilizes fixed ratio planetary rollers that are more efficient then traditional gear-wheels. Because the planetary rollers do not have teeth like traditional gear-wheels, noise is decreased and reliability increased. The closed oil circulation system cycles a specially-formulated Traction Oil that lubricates and cools the supercharger, dramatically increasing longevity and reliability. The Traction Oil is cooled through an air to fluid oil cooler.
The HKS Rotrex Supercharger kit for the Nissan 350Z includes all the necessary components for a complete installation:
HKS Rotrex Centrifugal Supercharger Unit
Front Mount Intercooler
S/C Controller (Engine Management w/direct plug harness)
Traction Oil Cooler
Tuned Cast-Aluminum Mounting Bracket (This bracket has been specifically engineered and tested to minimize noise and vibration)
525cc Injectors X 2
Bolt in Fuel Pump Assembly
Super Mega Flow Intake
Standard Bypass Valve
Pending CARB exemption
Website: http://www.hksusa.com/
ATI Procharger High Output Supercharger Kit
The new H.O. Intercooled ProCharger system for Nissan 350Zs produces a 55-60% horsepower gain (with a conservative 7 psi of boost) on stock motors running pump gas, with the ability to support even higher power levels. This supercharger system is a 100% complete bolt-on, and delivers the coolest charge air temperatures available, for maximum engine longevity as well as power. Standard equipment includes a highly effective air-to-air intercooler system and the self-contained, gear-driven C-2 ProCharger model, with 3-year supercharger warranty. Installation is very straightforward, with no accessory relocation, and can be completed in approximately 8-10 hours. A tuner kit for modified applications is also available.
The C-2 ProCharger for the 350Z features ATIs patented self-contained oiling technology, which delivers cooler operating temperatures and eliminates the need to punch a hole in the oil pan. The C-2 also features a patented progressively linked compound bearing system, which maintains reliability even with the higher boost and power levels possible with intercooling. Due to the positive impact of intercooling upon both performance and engine longevity, only intercooled ProCharger systems are being offered for the 350Z.
Website: http://www.procharger.com/
I think almost everyone on here will agree that both of your posts should become stickys. good job. I was suprised when i joined that there werent any. If people would add info to these as well as put in a average price and rwhp for each system that would be helpful also. I think alot of us have been searching around and only getting bits and pieces of info.
Sound like ATI Procharger is the best in the market because of 100% bolt-on (eliminates the need to punch a hole in the oil pan) and 3-year warranty. Thinking about of getting ATI Procharger over Vortech.
I go vortech with an oversized predrilled oil pan. Like the APS units. That way its still 100% bolt on and you can go back to stock.
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
n2fooz
Sep 4, 2015 07:46 PM
