Greddy Turbo
Old Aug 16, 2005 | 01:48 AM
aznx2cool4u's Avatar
Greddy Turbo
i was just wondering will a Greddy Twin Turbo work with an auto g35? i read on most sites selling the turbo that its designed for a 6mt. i wanted the 6mt but my parents bought the car auto =\
Old Aug 16, 2005 | 01:54 AM
GXCLUSIV's Avatar
Its true. However there is someone on this forum with a Greddy TT on a 5AT. Just find a shop that knows what their doing and they should be able to make it fit and work on your G. Just remember the Greddy kit is not complete out of box. You'll need other parts to make it run safely. Needs a qualified tuner.
Old Aug 16, 2005 | 02:11 AM
Whats a reliable turbo for a 5AT???
Old Aug 16, 2005 | 02:30 AM
GXCLUSIV's Avatar
If you want reliability for a 5AT, go SuperCharger instead, either Vortech SC or STillen SC. Both carb certified. If you must go Turbo, probably an APS Single-turbo or Turbonetics ST. For Twins, APS TT or SFR/SSR TT. Pros and Cons for all FI kits, just do some homework to determine which suits your budget and your power goals.
Old Aug 16, 2005 | 02:51 AM
sdkingka's Avatar
i was really interested in vortec sc, but the company site says they only designed for 6mt only. is there anyone who has vortec sc on a 5at? what has to be done to make sc work properly on 5at?
Old Aug 16, 2005 | 02:55 AM
G352NV's Avatar
Never enough
Yes Urban has one on his car. I installed it, its the same.
Old Aug 27, 2005 | 11:54 PM
tecni's Avatar
I'm getting my Greddy TT's put in. i dropped the car off on thurs and i've been helping out at the shop. So far the Intercooler, turbo manifolds, greddy oil pan, oil lines, reservoirs relocated, wastegates on.... Hopefully we'll be done on monday. BUT, I dunno if its just me and this shop's lack of expertise but things don't really seem to fit like they should. We often find ourselves struggling to reach the nuts and bolts... Does greddy make bad kits? Did I buy the wrong brand? Is APS better?
Old Aug 28, 2005 | 12:31 AM
G352NV's Avatar
Never enough
Oh boy! My best advice to you is to do some research on the 350z site about the greddy kit. I wouldnt even start the car without doing some research.
Old Aug 31, 2005 | 10:48 PM
hyperlitesmu's Avatar
2 Cars......2 Turbos...
The guy with a Greddy TT on an Automatic is called TXREFI on the forums. He is in Dallas. He had his work done at IDPG, the same place that installed my kit. The guys there talked about having to install a bleed valve, but once everything was worked out that guy is putting down over 500 whp. Give him a PM and ask him about it.
Old Sep 1, 2005 | 10:51 AM
Gman2004's Avatar
The only thing better about the APS TT IMO is 1. It comes with ball bearing turbos and 2. It is more complete out of the box. This does not mean the greddy can't be make as complete.
Before you drive that thing make sure you have an ignition harness and map sensor harness for tuning. Run it at stock boost and before you start boosting more psi you need to get a fuel return system and walbro 255 fuel pump. If you are going to stay at stock boost I would just go with technosquare and have your ECU flashed with the greddy tt map. I have not heard one motor blowing up that with map. Eitherway make sure you the fuel pump and a blow off valve.
g.spot
May 9, 2016 10:54 PM
HeyAsianKid
Intake & Exhaust
Oct 7, 2015 01:55 PM
ncg35guy
Sep 24, 2015 04:53 PM
