Innovate! Technology..look what's possible... VIDEO!!!
Old Oct 7, 2005 | 12:30 AM
GurgenPB's Avatar
Hey Guys
Just wanted to make this video that many were askign about...
I have got 16 channels going full blast... Here is what's possible with an LM-1, and LC-1, LMA-2, and TWO LMA-3's (AuxBoxes). This video of my the playback of an earlier log (which I always put up on my NAV screen with my in-car PC going). It's really a tremendous, end-all setup that allows up to 32channels going at the same time, each recorded at 12 samples per second.
Here is the video (rt-click...save as..):
VIDEO
So far:
Now, this is a work in progress of sorts..didn't quite make it before the car went under the knife again. So, the following as you can tell are not working yet (BTW..all of these were fixed in the beta 2 version of the AuxBox, just haven't had the time at all to load it in yet... but the firmware is about to go final int he next couple of weeks):
1. RPM
2. Timing Advance (which is refering RPM..hence not workign by extension)
3. EGT/CHT (cyl head temp)
ATF1 IS workig, that's just how the sensor fluctuates while the car is running (as per the service manual). Accel pedal is off only because I haven't head the time to calibrate it 9takes about 2 minutes)...
The video may not be up for long if I hit my bandwidth limit soon.
Just wanted to share...this is truly an awesome setup...I also have two XD-1's that i use when i need. Overall, this is a modular setup, and you get only how much and what you need. They also have two more unique modules coming out, for multi channel thermocouple readings and non-sensor AuxBoxes...
www.innovatemotorsports.com
Take care guys...let me know what you think.
Old Oct 7, 2005 | 12:48 AM
GXCLUSIV's Avatar
Great job Gurgen. Wish I could show that on my Nav screen. No more need for gauges.
Marlin84
Apr 1, 2020 12:52 PM
Picture Share
Feb 4, 2018 12:41 PM
f22raptor
Mar 18, 2016 08:50 AM
Red G Coupe
Video Share
Sep 28, 2015 06:29 PM
