Vortech with (re)built short block (*long*)
Old Oct 26, 2005 | 09:27 PM
  #31
booger's Avatar
I cant remember the exact settings for when the fuel pump should come on , but you may have had it set to run all the time . If your A/F was in the 9's all the time when boosting . Its possible you flushed the cyl. walls with fuel . And I've heard this may cause the crank bearings to go bad
I've also dropped my compression to 9 to1 with cams . havent notice a loss of trq. down low at all . My motor is out right now and dropping the comp. down to 8.5 to 1 . Upping the boost to 16 to 18psi
Old Oct 27, 2005 | 03:29 AM
  #32
GlenRoseFireFighter's Avatar
a.k.a. RANDYS_G
it's located in the alternate setting screen of the SS software...allows you to determine when the aux fuel pump comes on and mine was set at 7lbs! I set it at 3lbs...
alxmlr789
20 Inch
Jan 26, 2016 10:04 AM
reaper76
Sep 20, 2015 11:59 AM
ben_m
Engine - Intake/Fuel
Sep 7, 2015 10:04 PM
SilverG123
Engine - Electrical
Sep 4, 2015 01:12 PM
