Lil wisdom/advice from FI gurus requested
Old Oct 27, 2005 | 09:44 AM
Gman2004's Avatar
Originally Posted by PhxBlue
GMAN what did you with the top mounting brackets to make the radiator bolt up properly?
bullitproof dont be a buzz kill man, I refuse to believe you... *sigh*
sorry for the not responding sooner, but Wilma has left 99% of SFL with no power.
Look at the first and second picture I posted. The radiator does not have a 90 degree angle on the ends of the top. My shop made an L out of sheet metal and welded it on, then they cut the top bracket off of the radiator and moved it over to the L bracket they welded on. The 350z top bracket is a few inches inward vs. the location of the G's top brackets. If you look close enough on the 1st and 2nd picture you can see the scratch marks where the top brackets were oringially located.
gprabhu
19 Inch
Oct 2, 2015 05:55 PM
teamghost
Aug 19, 2015 04:01 PM
andresito7
Aug 1, 2015 04:53 AM
