oil cooler/radiator?
Old Nov 1, 2005 | 07:14 PM
paranormal's Avatar
how many people have upgraded there radiator and/or gotten an oil cooler.. i doubt any 05's have done this yet.. but how tight is it under the bumper.. and could you list what bumper you have.. any pics would be great.. also.. where did you get the oil cooler/ radiator and how much.... thanks
Old Nov 1, 2005 | 07:19 PM
PhxBlue's Avatar
Polyester Pileup FTW!
I can think of 2 oil coolers at the moment, 1) Nismo 1000+, 2) Stillen 392.00.
I have considered a radiator and read somewhere that the PE radiator is easier to make fit on an 05 than the Koyo.
Old Nov 6, 2005 | 06:50 PM
Eagle1's Avatar
I put the Koyo on the 6mt. It is TIGHT and you have to do a little shroud shaving. But it fits. The core is about three times the size of stock.
More importantly, it works fabulously. Combined with the ARC high capacity oil pan (now it runs a little under seven quarts of oil) the heat exchange works much better than before (and it was not bad before).
Old Nov 6, 2005 | 09:16 PM
Julian's Avatar
The Koyo is a PITA and you need to trim the radiator shroud alot and the lower radiator hose is REAAAAAALY close to the A/C compressor pulley..
MRC MOTORSPORTS
ALL THE FASTEST G'S ARE BUILT AT MRC'S
G35 Driver's OFFICIAL UTEC AND TURBO XS DEALER
UTEC INSIDE
Old Nov 6, 2005 | 10:52 PM
Gman2004's Avatar
no trimming needed with the PE. Just need to make new top brackets.
Attached Thumbnails oil cooler/radiator?-radiator-001.jpg   oil cooler/radiator?-radiator-004.jpg   oil cooler/radiator?-radiator-003.jpg   oil cooler/radiator?-radiator-002.jpg
f22raptor
Mar 18, 2016 08:50 AM
prinny
Nov 22, 2015 11:07 PM
mbe32
Nov 13, 2015 11:09 PM
9tray turbo
Sep 29, 2015 10:22 PM
