Update on APS ST on G35
Old Dec 8, 2005 | 12:37 AM
beastie's Avatar
Post Update on APS ST on G35
Past Issues:
Stuttering power
Turbo exhaust leak
Low power
Unable to hold boost
Resolutions:
Just installed EU
Tighted loose and missing bolts around turbo
Installed Greedy boost controller
Now:
Over all much better response and performance but still have some issues.
HP 338 TQ 360
Can't hold boost at higher RPM
Stalling often and takes several attempts to restart. ??
SES light (not sure cause yet)
One day everything will just work, One day...
Old Dec 8, 2005 | 01:33 AM
trey.hutcheson's Avatar
I suggest getting in contact with tig. He's had some issues with his st kit as well, but to my knowledge, he's now holding boost.
good luck
Old Dec 8, 2005 | 02:45 AM
accordfreak's Avatar
boost leak... check all your connections. you can check leaks by caping the turbo and use an aircompressor to pressurize the plumbing. AFter that, spray soapy water on all your connections to see where the leak is at.
Old Dec 8, 2005 | 06:34 AM
neffster's Avatar
I think just about EVERY APS ST has had the boost drop off. Tig is the man working the solution. Hit him up and he will help you out... he seems to be a good guy.
Old Dec 8, 2005 | 09:10 AM
beastie's Avatar
Very good idea. There has to be a leak.
I want a new BOV any suggestions. Also could a BOV be causing my stalling issues?
Old Dec 8, 2005 | 12:42 PM
beangrower's Avatar
i know that if its an open atmospheric BOV, the car tends to stumble, and sometimes die out on you...unless your car is tuned for it. maybe you should try to recirculate the valve? see if that helps.
Old Dec 8, 2005 | 03:30 PM
tig488's Avatar
APS comes as a recirculation system, i capped mine off and put a different bov, mine hasnt studdered once.
Old Dec 8, 2005 | 03:32 PM
tig488's Avatar
you can do what i did, take a coupler, put a short(~2 inch) pvc pipe capped off with a valve and pressure gauge on it, and hook that to a compressor, and hook it onto the turbo inlet and pressurize the system. mine held 18 psi, but i still had that boost leak. its the actuator.
Old Dec 8, 2005 | 04:06 PM
beangrower's Avatar
oh...den i dunno.
Old Dec 11, 2005 | 08:25 AM
Dsskyline's Avatar
Past Issues:
Stuttering power
Turbo exhaust leak
Low power
Resolutions:
Just installed EU
Now:
HP 338 TQ 360
Where do you have your EU installed in your car? I'm planning on getting the EU also I just want to see where you guys are placing it. Can you post pics if you can of where it is installed? Thanks
Old Dec 11, 2005 | 10:15 PM
beastie's Avatar
I had the EU installed under the passenger dash area.
netcbc
Exterior - Body Parts CDN
Aug 21, 2015 09:50 AM
VANST3R
Lights
Jul 27, 2015 08:20 PM
tiguy99
Jul 26, 2015 01:39 PM
laksjd84
Jul 24, 2015 05:12 PM
Chattzx
Jul 17, 2015 11:23 AM
