TT kit problem need help!!
Old Dec 18, 2005 | 10:29 AM
G35 Power's Avatar
Hi,
Just installed my APS TT kit on my 05 G35 6MT, The car is running good but it takes 4 to 5 seconds to start the engine, And the service engine and VDC lights are on, Any one can help. Thanks
Old Dec 19, 2005 | 10:58 AM
djniknala's Avatar
Get the DTC from the computer and then we'll try and help. You're not giving us much to go on.
Old Dec 19, 2005 | 11:19 AM
philogene's Avatar
mos high
I install mine no service engine light but the vdc. the alinment was off 143. so that might be your problem with the vdc.
Old Dec 21, 2005 | 12:50 PM
trebien's Avatar
Originally Posted by G35 Power
Hi,
Did you pull the red lever?
Old Dec 23, 2005 | 12:43 AM
KPierson's Avatar
If it takes a while to start the car it could possibly be a crank angle problem. Once the car is started, how does it run? Check the codes and give us some more info.
Old Dec 27, 2005 | 10:03 PM
panda007's Avatar
i can think of two possibilities: car is not getting enough fuel pressure to ignite. the CAS wire is not installed. double check everything and make sure they're all secured.
are all the vacuum hoses connected properly? is the CAS wire installed properly?
on a returnless fuel system equipped car that has been modified to a return system, it is imperative to add a bit of gas to crank the car.
Old Dec 28, 2005 | 07:24 PM
SI_G35Coupe's Avatar
could you elaborate on that point? this is the first time i'm hearing someone say this and i was curious if you could explain since i'll probably be going with a return style setup come FI time
Old Dec 28, 2005 | 09:35 PM
G352NV's Avatar
Never enough
Did you reset the ECU per APS instructions? Did you do the fuel pump update by drilling out the swirl jet? When you took the steering shaft off did it move from the orignal spot?
Old Dec 29, 2005 | 12:44 AM
narkotic's Avatar
crank angle sensor... never fails
Old Jan 6, 2006 | 01:37 PM
panda007's Avatar
i really don't know the specifics to why this happens but i think it's because of the initial fuel pressure during cranking. but i talked to sharif of forgedinternals.com, and he too has to add a bit of gas in order to crank his car with his GReddy TT and AAM fuel return system.
chinee
Jun 10, 2024 07:48 PM
Herbbie Hablib
Forced Induction
Aug 11, 2015 06:22 PM
chinee
Aug 8, 2015 10:11 AM
andrewvk
Interior
Aug 6, 2015 05:51 PM
attarday
Jul 15, 2015 04:03 PM
