How is the Gas mileage on Supercharged/Turbo G?
Old Jan 20, 2006 | 11:05 AM
CQQL's Avatar
Lightbulb How is the Gas mileage on Supercharged/Turbo G?
How is the Gas mileage any one? its poor as it is, how bad is it with Supercharged/Turbo ?
Old Jan 20, 2006 | 03:53 PM
BeerViper's Avatar
I am in the process of buying Randys_G, some of you might know it ... Vortech S/C at 6psi and he averages around 19 - 23. About the same if not better than what I get on my current stock G.
Old Jan 20, 2006 | 04:53 PM
BeerViper's Avatar
Hey Doc, from what he told me he is only pushing 6psi. Before he went with the Vortech he had already installed a true dual exhaust with high-flow cats. The Vortech system is designed to boost a stock G setup which means that the backpressure from the stock exhaust is taken into account.
I think the 366+ hp to the wheels will do me just fine after 2 years in my stock G. But then again, you never know
Old Jan 21, 2006 | 10:27 AM
NETSHARK's Avatar
BeerViper do you mean that if i installed Fujitsubo Exhaust with Y pipe the Vortech will perform well on it since its same settings as stock (not dual) ?
Old Jan 21, 2006 | 11:35 AM
Jtrain's Avatar
^ Yup
Old Jan 21, 2006 | 09:04 PM
BeerViper's Avatar
^^What he said.
Randys_G is using the stock 3.33 pully which is rated at 8psi. With the free flowing exhaust it is technically losing 2 psi although it is still putting down 366 rwhp and 300 rwtq. Essentially what it means is that you're still acheiving the same power output with a safer setup (less boost).
This is the way I understand it at least I'm sure I will keep learning a lot more once I take delivery of Randy's G
Old Jan 21, 2006 | 09:17 PM
urban's Avatar
I get 21.2 miles per gallon on the Vortech and I boost between 9.5 -10psi on the 3.12 pulley, I also have the fuji exhaust and y pipe and I also put down 420awhp.
I lost about 1.3 miles per gallon after the install.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
Rinaldi
Dec 2, 2015 05:29 PM
prinny
Nov 22, 2015 11:07 PM
Hogbone
Sep 28, 2015 06:44 PM
wow600rr
Sep 28, 2015 11:50 AM
